Error timeout
When I try to connect my Mikrotik SXT-5D I’ve got the following error :
I’m using windows 7
Thank for your help
It could be your network card. If you have another computer to try from then that may help. Otherwise you may have to connect over another interface on the routerboard or reset it to defaults. If its being unresponsive you can turn on netinstall on the pc and reboot the routerboard if it is having trouble booting then it may attempt to NetBoot.
The last time I had that happen I pressed the reset on my router and it began working. I connected expecting to have to reprogram it but the config wasn’t wiped. I’m still unclear what really happened.
