ERROR WARNING: package system-3.11 onuninstall script failed
I had replacing 5120 on RB112 n tried to netinstall
here was the process
MikroTik 2.9.20 <<<< these boot ok
Elka-Mertilang Login:<<<< forgot the password
RouterBOOT booter 2.2
RouterBoard 112
CPU frequency: 175 MHz
Memory size: 16 MB
Press any key within 2 seconds to enter setup.
RouterBOOT-2.2
What do you want to configure?
d - boot delay
k - boot key
s - serial console
o - boot device
u - cpu mode
r - reset configuration
e - format nand
g - upgrade firmware
i - board info
p - boot protocol
t - do memory testing
x - exit setup
your choice: o - boot device
Select boot device:
e - boot over Ethernet
  • n - boot from NAND, if fail then Ethernet
    1 - boot Ethernet once, then NAND
    o - boot from NAND only
    b - boot chosen device
    your choice: e - boot over Ethernet
RouterBOOT-2.2
d - boot delay
k - boot key
s - serial console
o - boot device
u - cpu mode
e - format nand
i - board info
p - boot protocol
x - exit setup
your choice: x - exit setup
writing settings to flash…
RouterBoard 112
Memory size: 16 MB
Press any key within 2 seconds to enter setup..
trying bootp protocol… OK
Got IP address: 192.168.2.250
resolved mac address 00:0A:E4:ED:E8:79
transfer started ************************************.*************************s
setting up elf image… OK
jumping to kernel code
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
mac-address: 00:0C:42:08:41:24
software-id: 75ND-3TT key:
EDITg6lacOpTdJO1vXyZ9ohOVzfaEQr35HkV1ZiYzPCfiewKpKYcJTemOzZ1xi/b6UbTUK5VeJl2ASx=
Waiting for installation server…
Found server at 00:0A:E4:ED:E8:79
Formatting disk…
ERROR: installation of routeros-rb500-2.9.50 failed: could not create lib/mobriy
WARNING: package system-2.9.50 onuninstall script failed<<<< doesNOT allow to write to NAND
Press ENTER to reboot
RouterBoard 112
Memory size: 16 MB
transfer started ***************************************.**********************s
RouterBoard 112
Memory size: 16 MB
RouterBOOT-2.2
d - boot delay
k - boot key
s - serial console
o - boot device
u - cpu mode
e - format nand
i - board info
p - boot protocol
x - exit setup
your choice: r - reset configuration
RouterBoard 112
Memory size: 16 MB
kernel not found
trying bootp protocol…d
kernel loadin
RouterBoard 112
Memory size: 16 MB
kernel not found<<<<my bad process as previously seen
trying bootp protocol…K
transfer started *************************************.************************s
Formatting disk…
WARNING: ghost file /
ERROR: installation of routeros-mipsle-3.11 failed: could not create : File exis
anyway to help, please
what is these error meant “onuninstall script failed”
success.. to upgrade to 3.30
step to do: install ROS to mem(soldering) from other board
