Error Code:
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Starting…
Oops in traps.c::do_be, line 385:
$0 : 00000000 1000e400 b8080000 00000001 c0115004 b8080000 00000000 b8080000
$8 : 1000e400 1000e401 00000002 00003d18 802a4bc4 00000002 1000e401 802e0000
$16: 83d18000 1000e401 00000013 00000013 00000000 00000000 c00ed000 83dcc000
$24: ba2e8ba3 00000000 83e00000 83e01cf8 1001b028 c00aba9c
Hi : 00000000
Lo : 00000c20
epc : 80256ad0 Tainted: P
Status: 1000e402
Cause : 0080001c
PrId : 0001800a
Process insmod (pid: 201, stackpage=83e00000)
Stack: 00000001 00000000 00000020 83d2dca0 83d18000 83d18000 c00aba9c
83d2dca0 83d70000 83d70284 c00965a8 c006d4d4 00000000 83d18000 c00abc68
83e01dca 83e01d40 83d24800 01c20001 83d24800 802a4e50 00000000 00000000
83d18000 c00abc0c 00000000 c00ac120 ffffffff 000005df 00010000 c0111000
00000000 00000000 8010dbd4 83d18000 83d18000 810ffc00 51110000 00000060
00000009 …
Call Trace: [] [] [] [] []
[] [<8010dbd4>] [] [<80105274>] [] []
[<80104a48>] [] [] [<80127410>] [] []
[<801c8e70>] [] [<801c8f3c>] [] [<80136248>] [<80116a2c>]
[<801162c0>] [] [<8010b3c0>] [<80186674>]
Code: 3c07b808 3c05b808 ace00048 <8c830000> 8ca30048 30620005 1040fffd 00031082 30420001
imq driver loaded.
RATE: registered
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
rb: starting…
rb: started
Starting services.
I have a 532A with 2 SR5’s and a 564 with 1 SR5. Everytime I reboot it gives me the same screen and will not get past “Starting services…” .
Then I removed the 564 all together, no screen, and boots fine. Put the 564 without the SR5 and boots fine. And when I put the SR5 back in, get the same problem. If I move the SR5 to another location on the same board same prob. If I move the SR5 back to the 532 boots fine, if I move the SR5 from the 532 that was working fine and move it to the 564 same prob again. I have tried this with 2 564’s with the same result. Also I have done a netinstall both with and without the 564.
