Error when setup PPPOE: terminating... - failed to authenticate ourselves to peer
Dear all,
I have a problem when try connect to ISP, they provide username/password to connect , but when im create PPPOE Client with WAN ether and put user/password (im sure right password) but status alway terminating… , when i see log system show: terminating… - failed to authenticate ourselves to peer, im try so more time but still that, how to fix that help me :frowning:
I don’t know why, but it happens if you’re using another profile, but not default-encryption. Set your PPP connection to use default-encryption and it will connect. I tried to create other profiles with the same settings as default-encryption, but they actually doesn’t work as default-encryption. I don’t know why, but it’s a fact checked many times on a few MikroTik routers with different 6.xx ROS.
Thank you for the tip, i have this problem sometimes too :slight_smile:
