Hello
i am facing two issues. 1st that i am working in an office with more then 40 users, with this setting internet traffic only use Wan 1 and if wan 1 goes down then it start using wan 2.
2nd thing my email server is hosted on cloud server after every 2 to 3 hours email sending and receiving stop automatically i am using outlook with incoming port 110 and outgoing port 25. but at this time internet works fine.
my configuration
may/20/2025 11:59:26 by RouterOS 6.49.16
software id = 60KX-MIKK
model = RB750Gr3
serial number = HGW0A35VTEY
set [ find default-name=ether1 ] name=ISP1
set [ find default-name=ether2 ] name=ISP2
set [ find default-name=ether5 ] name=LAN
/ip hotspot profile
add name=dhcp_pool1 ranges=192.168.0.105-192.168.0.199
add address-pool=dhcp_pool1 disabled=no interface=LAN name=dhcp1
add address=192.168.18.25/24 interface=ISP1 network=192.168.18.0
add address=192.168.98.20/24 interface=ISP2 network=192.168.98.0
add address=192.168.0.1/24 interface=LAN network=192.168.0.0
add address=192.168.0.0/24 gateway=192.168.0.1
set servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=facebook.com list=facebook.com
add address=fbcdn.net comment=facebook list=facebook.com
add address=m.facebook.com comment=facebook list=facebook.com
add action=drop chain=forward disabled=yes dst-address-list=facebook.com
add action=add-dst-to-address-list address-list=facebook.com
address-list-timeout=4d12h chain=forward comment=Facebook content=
.facebook.com src-address=192.168.0.0/24
address-list-timeout=4d12h chain=forward content=.facebook.net src-address=
192.168.0.0/24
address-list-timeout=4d12h chain=forward content=.fbcdn.net src-address=
192.168.0.0/24
/ip firewall mangle
add action=accept chain=prerouting dst-address=192.168.18.0/24 in-interface=LAN
add action=accept chain=prerouting dst-address=192.168.98.0/24 in-interface=LAN
add action=mark-connection chain=prerouting connection-mark=no-mark
in-interface=ISP1 new-connection-mark=ISP1_conn passthrough=yes
in-interface=ISP2 new-connection-mark=ISP2_conn passthrough=yes
dst-address-type=!local in-interface=LAN new-connection-mark=ISP1_conn
passthrough=no per-connection-classifier=both-addresses:2/0
dst-address-type=!local in-interface=LAN new-connection-mark=ISP2_conn
passthrough=no per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=ISP1_conn in-interface=
LAN new-routing-mark=to_ISP1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP2_conn in-interface=
LAN new-routing-mark=to_ISP2 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP1_conn new-routing-mark=
to_ISP1 passthrough=no
add action=mark-routing chain=output connection-mark=ISP2_conn new-routing-mark=
to_ISP2 passthrough=no
add action=change-mss chain=forward new-mss=clamp-to-pmtu passthrough=yes
protocol=tcp tcp-flags=syn
add action=masquerade chain=srcnat out-interface=ISP1
add action=masquerade chain=srcnat out-interface=ISP2
add action=dst-nat chain=dstnat dst-address=192.168.18.1 dst-port=1155 protocol=
tcp to-addresses=192.168.0.231 to-ports=1155
/ip firewall raw
add action=add-dst-to-address-list address-list=tiktok address-list-timeout=
none-dynamic chain=prerouting content=tiktok in-interface=LAN protocol=tcp
add action=drop chain=prerouting dst-address-list=tiktok
add action=drop chain=prerouting dst-address-list=facebook.com
address-list-timeout=none-dynamic chain=prerouting content=facebook
add check-gateway=ping distance=1 gateway=192.168.18.1 routing-mark=to_ISP1
add check-gateway=ping distance=1 gateway=192.168.18.1 routing-mark=to_ISP2
add check-gateway=ping distance=2 gateway=192.168.98.1
/system clock
set time-zone-name=Asia/Karachi
