Have an issue establishing connection between 2 Mikrotik devices, the configurtion is the following:
Mikrotik Router (CCR1072) one one hand, with an IP address on VLAN 999 (10.0.0.1/30 assigned to VLAN) on the other hand, a switch (CRS305) with and IP address on VLAN 999 also (10.0.0.2/30). The switch is working in bridge mode, with VLAN tagging defined in “Bridge” submenu. Cannot manage to communicate one device with another via IP. On the router side I see the mac address of the VLAN 999 on the switch but not vice versa.
On CRS305, I have tried configuring the PVID on the bridge port and the IP address directly on the bridge, untagging VLAN 999 on the physical port with no result. Also have tried defining VLAN 999 on the port (from Interfaces submenu) and assigning the IP address to the VLAN interface, with no result.
Have 2 questions:
- Which could be the solution?
- Which is the correct way of configuring the switch side in order to tag all the outcoming traffic from that interface (sfp+1) with VLAN 999 label in order to establish communication with the CCR1072 router?
Thank you in advance
Andrey.
