Dear all,
I read at http://wiki.mikrotik.com/wiki/Protecting_your_customers and there is firewall filter rules like this:
add chain=forward connection-state=established comment=“allow established connections”
add chain=forward connection-state=related comment=“allow related connections”
add chain=forward connection-state=invalid action=drop comment=“drop invalid connections”
and this is my firewall filters:
[admin@MikroTik] > /ip firewall filter print
0 ;;; DVR
chain=forward action=accept protocol=tcp dst-address=172.168.100.4
dst-port=8081
1 ;;; allow known IP Address
chain=forward action=accept src-address-list=allow
2 X ;;; accept established connection packets
chain=forward action=accept connection-state=established
3 ;;; accept related connection packets
chain=forward action=accept connection-state=related
4 ;;; allow access to router from local network
chain=input action=accept src-address=172.168.0.0/16 dst-address=172.168.100.1
in-interface=ether2-local
5 ;;; allow ICMP from local
chain=forward action=accept protocol=icmp src-address=172.168.0.0/16
6 ;;; portknock 1
chain=input action=add-src-to-address-list protocol=tcp address-list=knock
address-list-timeout=30s dst-port=1234
7 ;;; portknock 2
chain=input action=add-src-to-address-list protocol=tcp src-address-list=knock
address-list=safe address-list-timeout=15m dst-port=4321
8 ;;; allow access to router from known network
chain=input action=accept src-address-list=safe
9 ;;; accept established connection packets
chain=input action=accept connection-state=established
in-interface=ether1-firstmedia
10 ;;; accept established connection packets
in-interface=ether3-speedy
11 ;;; accept related connection packets
chain=input action=accept connection-state=related
12 ;;; accept related connection packets
chain=input action=accept connection-state=related in-interface=ether3-speedy
13 ;;; allow ICMP
chain=input action=accept protocol=icmp in-interface=ether1-firstmedia
14 ;;; allow ICMP
chain=input action=accept protocol=icmp in-interface=ether3-speedy
15 ;;; drop invalid packets
chain=input action=drop connection-state=invalid
16 ;;; drop others
17 ;;; drop unknown IP Address
chain=forward action=drop src-address=172.168.0.0/16
As you see above, i have this specific rules:
So, the problem is everytime i disable someone ip at address list, that computer still can access internet, recently i know why not automatic disable internet connection, because this rule:
So, after i disable this one.. if i disable / enable someone IP at address list, it will automatically turn off / turn on internet connection.
Alternatively, i must delete established connections:
[admin@MikroTik] > /ip firewall connection print
or reboot the MikroTik device
My questions are:
What is the problem if i don’t use that filter rules? Specially the first rule.
Thank you
Best Regards,
Yudi Wijaya
