Hello.
Some time ago decided to replace my home ASUS RTN12 to Mikrotik RB2011iLS-in.
Configiration on Mikrotik - standart. Just local DHCP 192.168.1.101-200 and masquerade to get access from local to internet.
Some times I need to be able to connect from home to my corporate-network from corporate-laptop.
For this there is Cisco VPN-Client installed on Laptop.
So just after I replace my simple ASUS router i faced with problem - I cant establish VPN-connection trough Mikrotik to access corporate Netwrok. If I put back ASUS - everything OK, so it isnt provider issue, it is smth wrong with configuration.
What should to be configured to allow VPN connection from my local 192.168.1.0/24 to corporate-netwrok trough Mikrotik using Cisco VPN client on Laptop.
Does it mean, that you have some Cisco device running VPN server in your corporate network? If so, you probably need to set MikroTik to accept and/or passthrough protocols and/or set up port forwarding to the server.
Thank you for your reply.
Yes, there is Cisco firewalls in corporate netwrok.
I have Cisco VPN client on my corporate computer and profile to connect.
Problem that simle ASUS allow to connect to it and my Mikrotik router no.
I understand that smth miss/nonconfigured on Mikrotik.
Could you help to understand which protocols I need to accept or which rule i have to correct or add?
[Admin@RT_209] > /ip firewall nat print
0 chain=srcnat action=masquerade src-address=192.168.1.0/24
dst-address=0.0.0.0/0 out-interface=Rostelecom log=no log-prefix=“”
1 D ;;; upnp 192.168.1.120: 192.168.1.120:9308 to 9308 (UDP)
chain=dstnat action=dst-nat to-addresses=192.168.1.120 to-ports=9308
protocol=udp dst-address=77.51.93.98 in-interface=Rostelecom
dst-port=9308
2 D ;;; upnp 192.168.1.120: EA Tunnel
chain=dstnat action=dst-nat to-addresses=192.168.1.120 to-ports=3659
dst-port=3659
/ip firewall service-port print
NAME PORTS
0 ftp 21
1 tftp 69
2 irc 6667
3 h323
4 sip 5060
5061
5 pptp
6 udplite
7 dccp
8 sctp
/ip route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 Rostelecom 0
1 ADC 192.168.1.0/24 192.168.1.1 BR1-LAN 0
2 ADC 213.140.228.144/32 77.51.93.98 Rostelecom 0
