tatad zem “”/interface>print" radiokartachkam nerada nekadu stavokli! nav ne x ne R ? vai tas nozime ka man nav pieinstaleti draiveri vinjam??
tas noziimee, ka wireless kartinja nav piesleegusies pie AP, vai arii pie AP (shiis kartinjas) nav neviens klients piesleedzies ![]()
Ar karti viss kaartiibaa - nekaadus draiverus nevajag. Paarbaudiet wireless konfiguraaciju.
tatad bez klienta man neuzradisies ka kartinaj strada???
R - nenozime ka kartinja strada vai ne, tas nozime ka karte ir ar kautko savienojusies
bet ja tur neko nerada!! ?
nu kaa ja “R” ir - tatad IR PIESLEDZIES
ja nekaa nav tad NAV NEKUR PIESLEDZIES
tik vienkarshi! kur ir problema?
aha skaidrs! kur un ka es varet moradit diapazonu <2.4 & 5.2Ghz> un frkvenci kartachkai???
uzrakstiet sekojoshas komandas routerii:
/interface wireless
tad [enter] taustinju un tad rakstiret:
print
redzesiet visas iespejamas opcijas. kautko mainit var ar set komandu. piemeram frekvenci uzstadam:
set wlan1 frequency=2345
vairak informacijas sheit:
http://www.mikrotik.com/docs/ros/2.9/interface/wireless
(pasha sakuma izlasiet QUICK SETUP GUIDE!)
paldiezzzz… =D
Informacijai: [enter] taustinju var atrast uz klaviaturas (tads liels taustinsh zem [backspace])
ha..ha! nu smejies vien… =D
OK, just what was discussed here?
I think it was a plot ! ![]()
Craig
Does it thicken?? ![]()
I have NO CLUE ! ![]()
The main disscusion was about how to find [enter] on keyboard ![]()
Tell me your kidding!! ![]()
Craig
He’s not kidding ![]()
RIIIIGHTTT!!!
Then this one needs to be archived.. we dont want to loose it.
