I am struggling to setup Mikrotik CHR on ESXI 6.5 with Intel 82599ES 10Gb SFP+ Adapter but its showing weird issues which i have tried to resolve since a week but i am failing in all aspects.
Issue :
When Mikrotik CHR is used with 1G Virtual NIC , everything works perfectly.
When Mikrotik CHR is used with 10G Intel 82599ES , I see vmware throwing logs of adapter reset. Error log below
[root@localhost:~] tail -f /var/log/vmkernel.log
2017-04-27T10:55:09.197Z cpu22:70056)NetSched: 628: vmnic2-5-tx: worldID = 70056 exits
2017-04-27T10:55:09.197Z cpu27:70054)NetSched: 628: vmnic2-3-tx: worldID = 70054 exits
2017-04-27T10:55:09.197Z cpu14:70052)NetSched: 628: vmnic2-1-tx: worldID = 70052 exits
2017-04-27T10:55:09.197Z cpu0:70058)NetSched: 628: vmnic2-7-tx: worldID = 70058 exits
2017-04-27T10:55:09.197Z cpu30:70053)NetSched: 628: vmnic2-2-tx: worldID = 70053 exits
2017-04-27T10:55:09.197Z cpu23:65645)NetLB: 2246: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2017-04-27T10:55:09.197Z cpu19:70057)NetSched: 628: vmnic2-6-tx: worldID = 70057 exits
2017-04-27T10:55:09.197Z cpu23:65645)NetLB: 2242: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2017-04-27T10:55:09.197Z cpu23:65645)Uplink: 9893: enabled port 0x3000002 with mac 00:1b:21:bc:7f:0c
2017-04-27T10:55:09.197Z cpu23:70055)NetSched: 628: vmnic2-4-tx: worldID = 70055 exits
2017-04-27T10:56:29.460Z cpu14:65550)<6>ixgbe 0000:01:00.0: vmnic2: Received unrecoverable ECC Err, please reboot
2017-04-27T10:56:34.033Z cpu19:66175)<3>ixgbe 0000:01:00.0: vmnic2: Detected Tx Unit Hang
Tx Queue <0>
TDH, TDT <14f>, <15c>
next_to_use <15c>
next_to_clean <14f>
2017-04-27T10:56:34.033Z cpu19:66175)<3>ixgbe 0000:01:00.0: vmnic2: tx_buffer_info[next_to_clean]
time_stamp <28d9e>
jiffies <28f67>
2017-04-27T10:56:34.033Z cpu19:66175)<6>ixgbe 0000:01:00.0: vmnic2: tx hang 29 detected on queue 0, resetting adapter
2017-04-27T10:56:34.033Z cpu11:66097)<3>ixgbe 0000:01:00.0: vmnic2: Reset adapter
2017-04-27T10:56:34.265Z cpu11:66097)<6>ixgbe 0000:01:00.0: vmnic2: detected SFP+: 5
2017-04-27T10:56:34.505Z cpu11:66097)<6>ixgbe 0000:01:00.0: vmnic2: NIC Link is Up 10 Gbps, Flow Control: None
2017-04-27T10:56:35.198Z cpu0:65645)NetPort: 1879: disabled port 0x3000002
2017-04-27T10:56:35.198Z cpu6:70059)NetSched: 628: vmnic2-0-tx: worldID = 70059 exits
2017-04-27T10:56:35.198Z cpu1:70060)NetSched: 628: vmnic2-1-tx: worldID = 70060 exits
2017-04-27T10:56:35.198Z cpu13:70061)NetSched: 628: vmnic2-2-tx: worldID = 70061 exits
2017-04-27T10:56:35.198Z cpu14:70063)NetSched: 628: vmnic2-4-tx: worldID = 70063 exits
2017-04-27T10:56:35.198Z cpu18:70064)NetSched: 628: vmnic2-5-tx: worldID = 70064 exits
2017-04-27T10:56:35.198Z cpu20:70065)NetSched: 628: vmnic2-6-tx: worldID = 70065 exits
2017-04-27T10:56:35.198Z cpu6:70062)NetSched: 628: vmnic2-3-tx: worldID = 70062 exits
2017-04-27T10:56:35.198Z cpu22:70066)NetSched: 628: vmnic2-7-tx: worldID = 70066 exits
2017-04-27T10:56:35.198Z cpu0:65645)NetLB: 2246: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2017-04-27T10:56:35.198Z cpu0:65645)NetLB: 2242: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2017-04-27T10:56:35.198Z cpu0:65645)Uplink: 9893: enabled port 0x3000002 with mac 00:1b:21:bc:7f:0c
2017-04-27T10:56:36.197Z cpu0:65645)NetPort: 1879: disabled port 0x3000002
2017-04-27T10:56:36.197Z cpu1:70069)NetSched: 628: vmnic2-0-tx: worldID = 70069 exits
2017-04-27T10:56:36.197Z cpu21:70070)NetSched: 628: vmnic2-1-tx: worldID = 70070 exits
2017-04-27T10:56:36.197Z cpu6:70071)NetSched: 628: vmnic2-2-tx: worldID = 70071 exits
2017-04-27T10:56:36.197Z cpu16:70072)NetSched: 628: vmnic2-3-tx: worldID = 70072 exits
2017-04-27T10:56:36.197Z cpu19:70073)NetSched: 628: vmnic2-4-tx: worldID = 70073 exits
2017-04-27T10:56:36.197Z cpu22:70074)NetSched: 628: vmnic2-5-tx: worldID = 70074 exits
2017-04-27T10:56:36.197Z cpu26:70075)NetSched: 628: vmnic2-6-tx: worldID = 70075 exits
2017-04-27T10:56:36.197Z cpu12:70076)NetSched: 628: vmnic2-7-tx: worldID = 70076 exits
2017-04-27T10:56:36.197Z cpu0:65645)NetLB: 2246: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2017-04-27T10:56:36.197Z cpu0:65645)NetLB: 2242: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2017-04-27T10:56:36.198Z cpu0:65645)Uplink: 9893: enabled port 0x3000002 with mac 00:1b:21:bc:7f:0c
2017-04-27T10:56:52.520Z cpu14:66363)<6>ixgbe 0000:01:00.0: vmnic2: Received unrecoverable ECC Err, please reboot
2017-04-27T10:56:56.630Z cpu19:66175)<3>ixgbe 0000:01:00.0: vmnic2: Detected Tx Unit Hang
Tx Queue <0>
TDH, TDT <87>, <9f>
next_to_use <9f>
next_to_clean <87>
2017-04-27T10:56:56.630Z cpu19:66175)<3>ixgbe 0000:01:00.0: vmnic2: tx_buffer_info[next_to_clean]
time_stamp <296a0>
jiffies <2983b>
2017-04-27T10:56:56.630Z cpu19:66175)<6>ixgbe 0000:01:00.0: vmnic2: tx hang 30 detected on queue 0, resetting adapter
2017-04-27T10:56:56.630Z cpu9:66095)<3>ixgbe 0000:01:00.0: vmnic2: Reset adapter
2017-04-27T10:56:56.867Z cpu9:66095)<6>ixgbe 0000:01:00.0: vmnic2: detected SFP+: 5
2017-04-27T10:56:57.107Z cpu9:66095)<6>ixgbe 0000:01:00.0: vmnic2: NIC Link is Up 10 Gbps, Flow Control: None
2017-04-27T10:56:57.198Z cpu0:65645)NetPort: 1879: disabled port 0x3000002
2017-04-27T10:56:57.198Z cpu7:70077)NetSched: 628: vmnic2-0-tx: worldID = 70077 exits
2017-04-27T10:56:57.198Z cpu10:70078)NetSched: 628: vmnic2-1-tx: worldID = 70078 exits
2017-04-27T10:56:57.198Z cpu13:70079)NetSched: 628: vmnic2-2-tx: worldID = 70079 exits
2017-04-27T10:56:57.198Z cpu14:70080)NetSched: 628: vmnic2-3-tx: worldID = 70080 exits
2017-04-27T10:56:57.198Z cpu2:70081)NetSched: 628: vmnic2-4-tx: worldID = 70081 exits
2017-04-27T10:56:57.198Z cpu26:70082)NetSched: 628: vmnic2-5-tx: worldID = 70082 exits
2017-04-27T10:56:57.198Z cpu17:70083)NetSched: 628: vmnic2-6-tx: worldID = 70083 exits
2017-04-27T10:56:57.198Z cpu18:70084)NetSched: 628: vmnic2-7-tx: worldID = 70084 exits
2017-04-27T10:56:57.198Z cpu0:65645)NetLB: 2246: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2017-04-27T10:56:57.198Z cpu0:65645)NetLB: 2242: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2017-04-27T10:56:57.198Z cpu0:65645)Uplink: 9893: enabled port 0x3000002 with mac 00:1b:21:bc:7f:0c
2017-04-27T10:57:01.075Z cpu14:66363)<6>ixgbe 0000:01:00.0: vmnic2: Received unrecoverable ECC Err, please reboot
2017-04-27T10:57:05.213Z cpu19:66175)<3>ixgbe 0000:01:00.0: vmnic2: Detected Tx Unit Hang
Tx Queue <0>
TDH, TDT , <1c>
next_to_use <1c>
next_to_clean
2017-04-27T10:57:05.213Z cpu19:66175)<3>ixgbe 0000:01:00.0: vmnic2: tx_buffer_info[next_to_clean]
time_stamp <299f7>
jiffies <29b95>
2017-04-27T10:57:05.213Z cpu19:66175)<6>ixgbe 0000:01:00.0: vmnic2: tx hang 31 detected on queue 0, resetting adapter
2017-04-27T10:57:05.213Z cpu1:66091)<3>ixgbe 0000:01:00.0: vmnic2: Reset adapter
2017-04-27T10:57:05.445Z cpu1:66091)<6>ixgbe 0000:01:00.0: vmnic2: detected SFP+: 5
2017-04-27T10:57:05.685Z cpu1:66091)<6>ixgbe 0000:01:00.0: vmnic2: NIC Link is Up 10 Gbps, Flow Control: None
2017-04-27T10:57:11.198Z cpu0:65645)NetPort: 1879: disabled port 0x3000002
2017-04-27T10:57:11.198Z cpu10:70086)NetSched: 628: vmnic2-0-tx: worldID = 70086 exits
2017-04-27T10:57:11.198Z cpu3:70087)NetSched: 628: vmnic2-1-tx: worldID = 70087 exits
2017-04-27T10:57:11.198Z cpu6:70088)NetSched: 628: vmnic2-2-tx: worldID = 70088 exits
2017-04-27T10:57:11.198Z cpu8:70089)NetSched: 628: vmnic2-3-tx: worldID = 70089 exits
2017-04-27T10:57:11.198Z cpu13:70091)NetSched: 628: vmnic2-5-tx: worldID = 70091 exits
2017-04-27T10:57:11.198Z cpu14:70092)NetSched: 628: vmnic2-6-tx: worldID = 70092 exits
2017-04-27T10:57:11.198Z cpu22:70093)NetSched: 628: vmnic2-7-tx: worldID = 70093 exits
2017-04-27T10:57:11.198Z cpu0:65645)NetLB: 2246: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2017-04-27T10:57:11.198Z cpu0:65645)NetLB: 2242: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2017-04-27T10:57:11.198Z cpu10:70090)NetSched: 628: vmnic2-4-tx: worldID = 70090 exits
2017-04-27T10:57:11.198Z cpu0:65645)Uplink: 9893: enabled port 0x3000002 with mac 00:1b:21:bc:7f:0c
2017-04-27T10:57:12.198Z cpu0:65645)NetPort: 1879: disabled port 0x3000002
2017-04-27T10:57:12.198Z cpu8:70095)NetSched: 628: vmnic2-0-tx: worldID = 70095 exits
2017-04-27T10:57:12.198Z cpu10:70094)NetSched: 628: vmnic2-1-tx: worldID = 70094 exits
2017-04-27T10:57:12.198Z cpu27:70096)NetSched: 628: vmnic2-2-tx: worldID = 70096 exits
2017-04-27T10:57:12.198Z cpu24:70097)NetSched: 628: vmnic2-3-tx: worldID = 70097 exits
2017-04-27T10:57:12.198Z cpu2:70098)NetSched: 628: vmnic2-4-tx: worldID = 70098 exits
2017-04-27T10:57:12.198Z cpu17:70099)NetSched: 628: vmnic2-5-tx: worldID = 70099 exits
2017-04-27T10:57:12.198Z cpu13:70101)NetSched: 628: vmnic2-7-tx: worldID = 70101 exits
2017-04-27T10:57:12.198Z cpu0:65645)NetLB: 2246: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2017-04-27T10:57:12.198Z cpu0:65645)NetLB: 2242: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2017-04-27T10:57:12.198Z cpu0:65645)Uplink: 9893: enabled port 0x3000002 with mac 00:1b:21:bc:7f:0c
2017-04-27T10:57:12.198Z cpu18:70100)NetSched: 628: vmnic2-6-tx: worldID = 70100 exits
2017-04-27T10:57:19.877Z cpu14:66181)<6>ixgbe 0000:01:00.0: vmnic2: Received unrecoverable ECC Err, please reboot
2017-04-27T10:57:23.799Z cpu31:66175)<3>ixgbe 0000:01:00.0: vmnic2: Detected Tx Unit Hang
Tx Queue <0>
TDH, TDT <4d>, <65>
next_to_use <65>
next_to_clean <4d>
2017-04-27T10:57:23.799Z cpu31:66175)<3>ixgbe 0000:01:00.0: vmnic2: tx_buffer_info[next_to_clean]
time_stamp <2a14f>
jiffies <2a2d8>
2017-04-27T10:57:23.799Z cpu31:66175)<6>ixgbe 0000:01:00.0: vmnic2: tx hang 32 detected on queue 0, resetting adapter
2017-04-27T10:57:23.799Z cpu9:66108)<3>ixgbe 0000:01:00.0: vmnic2: Reset adapter
2017-04-27T10:57:24.030Z cpu9:66108)<6>ixgbe 0000:01:00.0: vmnic2: detected SFP+: 5
2017-04-27T10:57:24.270Z cpu9:66108)<6>ixgbe 0000:01:00.0: vmnic2: NIC Link is Up 10 Gbps, Flow Control: None
2017-04-27T10:57:25.198Z cpu0:65645)NetPort: 1879: disabled port 0x3000002
2017-04-27T10:57:25.198Z cpu2:70102)NetSched: 628: vmnic2-0-tx: worldID = 70102 exits
2017-04-27T10:57:25.198Z cpu10:70103)NetSched: 628: vmnic2-1-tx: worldID = 70103 exits
2017-04-27T10:57:25.198Z cpu19:70104)NetSched: 628: vmnic2-2-tx: worldID = 70104 exits
2017-04-27T10:57:25.198Z cpu7:70105)NetSched: 628: vmnic2-3-tx: worldID = 70105 exits
2017-04-27T10:57:25.198Z cpu13:70106)NetSched: 628: vmnic2-4-tx: worldID = 70106 exits
2017-04-27T10:57:25.198Z cpu14:70107)NetSched: 628: vmnic2-5-tx: worldID = 70107 exits
2017-04-27T10:57:25.198Z cpu20:70108)NetSched: 628: vmnic2-6-tx: worldID = 70108 exits
2017-04-27T10:57:25.198Z cpu24:70109)NetSched: 628: vmnic2-7-tx: worldID = 70109 exits
2017-04-27T10:57:25.198Z cpu0:65645)NetLB: 2246: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2017-04-27T10:57:25.198Z cpu0:65645)NetLB: 2242: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2017-04-27T10:57:25.198Z cpu0:65645)Uplink: 9893: enabled port 0x3000002 with mac 00:1b:21:bc:7f:0c
2017-04-27T10:57:26.196Z cpu0:65645)NetPort: 1879: disabled port 0x3000002
2017-04-27T10:57:26.196Z cpu7:70110)NetSched: 628: vmnic2-0-tx: worldID = 70110 exits
2017-04-27T10:57:26.196Z cpu14:70116)NetSched: 628: vmnic2-6-tx: worldID = 70116 exits
2017-04-27T10:57:26.196Z cpu24:70112)NetSched: 628: vmnic2-2-tx: worldID = 70112 exits
2017-04-27T10:57:26.196Z cpu29:70114)NetSched: 628: vmnic2-4-tx: worldID = 70114 exits
2017-04-27T10:57:26.196Z cpu21:70111)NetSched: 628: vmnic2-1-tx: worldID = 70111 exits
2017-04-27T10:57:26.196Z cpu19:70117)NetSched: 628: vmnic2-7-tx: worldID = 70117 exits
2017-04-27T10:57:26.196Z cpu10:70113)NetSched: 628: vmnic2-3-tx: worldID = 70113 exits
2017-04-27T10:57:26.196Z cpu0:65645)NetLB: 2246: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2017-04-27T10:57:26.196Z cpu0:65645)NetLB: 2242: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2017-04-27T10:57:26.196Z cpu3:70115)NetSched: 628: vmnic2-5-tx: worldID = 70115 exits
2017-04-27T10:57:26.196Z cpu0:65645)Uplink: 9893: enabled port 0x3000002 with mac 00:1b:21:bc:7f:0c
2017-04-27T10:57:28.877Z cpu14:66181)<6>ixgbe 0000:01:00.0: vmnic2: Received unrecoverable ECC Err, please reboot
2017-04-27T10:57:34.382Z cpu31:66175)<3>ixgbe 0000:01:00.0: vmnic2: Detected Tx Unit Hang
Tx Queue <0>
TDH, TDT <25>, <44>
next_to_use <44>
next_to_clean <25>
2017-04-27T10:57:34.382Z cpu31:66175)<3>ixgbe 0000:01:00.0: vmnic2: tx_buffer_info[next_to_clean]
time_stamp <2a4d3>
jiffies <2a6fa>
2017-04-27T10:57:34.382Z cpu31:66175)<6>ixgbe 0000:01:00.0: vmnic2: tx hang 33 detected on queue 0, resetting adapter
2017-04-27T10:57:34.382Z cpu9:66086)<3>ixgbe 0000:01:00.0: vmnic2: Reset adapter
2017-04-27T10:57:34.613Z cpu9:66086)<6>ixgbe 0000:01:00.0: vmnic2: detected SFP+: 5
2017-04-27T10:57:34.853Z cpu9:66086)<6>ixgbe 0000:01:00.0: vmnic2: NIC Link is Up 10 Gbps, Flow Control: None
2017-04-27T10:57:36.198Z cpu0:65645)NetPort: 1879: disabled port 0x3000002
2017-04-27T10:57:36.198Z cpu8:70118)NetSched: 628: vmnic2-0-tx: worldID = 70118 exits
2017-04-27T10:57:36.198Z cpu19:70120)NetSched: 628: vmnic2-2-tx: worldID = 70120 exits
2017-04-27T10:57:36.198Z cpu10:70119)NetSched: 628: vmnic2-1-tx: worldID = 70119 exits
2017-04-27T10:57:36.198Z cpu7:70121)NetSched: 628: vmnic2-3-tx: worldID = 70121 exits
2017-04-27T10:57:36.198Z cpu26:70123)NetSched: 628: vmnic2-5-tx: worldID = 70123 exits
2017-04-27T10:57:36.198Z cpu20:70124)NetSched: 628: vmnic2-6-tx: worldID = 70124 exits
2017-04-27T10:57:36.198Z cpu30:70125)NetSched: 628: vmnic2-7-tx: worldID = 70125 exits
2017-04-27T10:57:36.198Z cpu0:65645)NetLB: 2246: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2017-04-27T10:57:36.198Z cpu0:65645)NetLB: 2242: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2017-04-27T10:57:36.198Z cpu14:70122)NetSched: 628: vmnic2-4-tx: worldID = 70122 exits
2017-04-27T10:57:36.198Z cpu0:65645)Uplink: 9893: enabled port 0x3000002 with mac 00:1b:21:bc:7f:0c
2017-04-27T10:57:37.198Z cpu13:65645)NetPort: 1879: disabled port 0x3000002
2017-04-27T10:57:37.198Z cpu6:70126)NetSched: 628: vmnic2-0-tx: worldID = 70126 exits
2017-04-27T10:57:37.198Z cpu20:70127)NetSched: 628: vmnic2-1-tx: worldID = 70127 exits
2017-04-27T10:57:37.198Z cpu23:70128)NetSched: 628: vmnic2-2-tx: worldID = 70128 exits
2017-04-27T10:57:37.198Z cpu8:70129)NetSched: 628: vmnic2-3-tx: worldID = 70129 exits
2017-04-27T10:57:37.198Z cpu30:70130)NetSched: 628: vmnic2-4-tx: worldID = 70130 exits
2017-04-27T10:57:37.198Z cpu10:70132)NetSched: 628: vmnic2-6-tx: worldID = 70132 exits
2017-04-27T10:57:37.198Z cpu26:70133)NetSched: 628: vmnic2-7-tx: worldID = 70133 exits
2017-04-27T10:57:37.198Z cpu13:65645)NetLB: 2246: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2017-04-27T10:57:37.198Z cpu13:65645)NetLB: 2242: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2017-04-27T10:57:37.198Z cpu6:70131)NetSched: 628: vmnic2-5-tx: worldID = 70131 exits
2017-04-27T10:57:37.198Z cpu13:65645)Uplink: 9893: enabled port 0x3000002 with mac 00:1b:21:bc:7f:0c
2017-04-27T10:57:39.997Z cpu14:67716)<6>ixgbe 0000:01:00.0: vmnic2: Received unrecoverable ECC Err, please reboot
2017-04-27T10:57:44.965Z cpu31:66175)<3>ixgbe 0000:01:00.0: vmnic2: Detected Tx Unit Hang
Tx Queue <0>
TDH, TDT , <1e>
next_to_use <1e>
next_to_clean
2017-04-27T10:57:44.965Z cpu31:66175)<3>ixgbe 0000:01:00.0: vmnic2: tx_buffer_info[next_to_clean]
time_stamp <2a92b>
jiffies <2ab1c>
2017-04-27T10:57:44.965Z cpu31:66175)<6>ixgbe 0000:01:00.0: vmnic2: tx hang 34 detected on queue 0, resetting adapter
2017-04-27T10:57:44.965Z cpu10:66104)<3>ixgbe 0000:01:00.0: vmnic2: Reset adapter
2017-04-27T10:57:45.196Z cpu10:66104)<6>ixgbe 0000:01:00.0: vmnic2: detected SFP+: 5
2017-04-27T10:57:45.436Z cpu10:66104)<6>ixgbe 0000:01:00.0: vmnic2: NIC Link is Up 10 Gbps, Flow Control: None
2017-04-27T10:57:48.198Z cpu17:65645)NetPort: 1879: disabled port 0x3000002
2017-04-27T10:57:48.198Z cpu19:70136)NetSched: 628: vmnic2-2-tx: worldID = 70136 exits
2017-04-27T10:57:48.198Z cpu6:70134)NetSched: 628: vmnic2-0-tx: worldID = 70134 exits
2017-04-27T10:57:48.198Z cpu25:70135)NetSched: 628: vmnic2-1-tx: worldID = 70135 exits
2017-04-27T10:57:48.198Z cpu12:70137)NetSched: 628: vmnic2-3-tx: worldID = 70137 exits
2017-04-27T10:57:48.198Z cpu14:70139)NetSched: 628: vmnic2-5-tx: worldID = 70139 exits
2017-04-27T10:57:48.198Z cpu1:70140)NetSched: 628: vmnic2-6-tx: worldID = 70140 exits
2017-04-27T10:57:48.198Z cpu27:70141)NetSched: 628: vmnic2-7-tx: worldID = 70141 exits
2017-04-27T10:57:48.198Z cpu17:65645)NetLB: 2246: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2017-04-27T10:57:48.198Z cpu17:65645)NetLB: 2242: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2017-04-27T10:57:48.198Z cpu17:65645)Uplink: 9893: enabled port 0x3000002 with mac 00:1b:21:bc:7f:0c
2017-04-27T10:57:48.198Z cpu31:70138)NetSched: 628: vmnic2-4-tx: worldID = 70138 exits
If anyone needs further logs , it will be shared promptly.
Any help on this will be highly appreciated.
