Mikrotik Staff do you have an ETA on the Beta3?
1-3weeks? ![]()
Many fundamental changes (kernel upgrade) so it will take a few more days. Probably next week.
Hi Normis,
Sounds promising
looking forward to it.
Keep up the good work!
6.0beta3 RB433UAH 30min CPU ? … winbox 2-43%CPU
RB133 5.17rc1 OK
Translation: We’re too busy playing Diablo 3. Check again after we hit level 60 and finish inferno mode. ![]()
j/k … I’m sure they’re hard at work putting in lots of awesomeness into this and it takes a while sometimes to make it work good.
Any news Normis on beta3? ![]()
it will take a while. So no ETA.
Some hints on whats to come in beta3? ![]()
this is the major change which takes a while:
*) upgraded drivers and kernel (to linux-3.3.5);
Okay no new features ? ![]()
what about new routing?..
If it is not released, then there must be multiple versions of 6.0beta3 because I saw a link for it a week or so ago, and so I downloaded it and I’ve been using it already.
Look around, the link for it may still be active.
Just like any version, we make many builds before releasing to public.
Is there a Beta of the beta3? ![]()
And if so where can I get it to try? I have an RB800…
6.0beta3 (16.05. 2012) load CPU winbox (www statistics OK)
6.0beta3 (04.06. 2012) load CPU RB433UAH statistics tools/profile/www -80% problems with displaying charts … [load CPU Winbox => OK corrected?]
Normis, 6.0beta3 from date 4.6.2012 is based on new kernel? Thanks
6.0beta3 = Linux Kernel 3.3.5
Here’s a bug with b3:
Sometimes, after awhile (days), I can no longer connect with Winbox. Everything else keeps working fine, but the router won’t respond to a winbox connection. Power cycling the router makes winbox connect fine again.
Another bug with beta3 04.05.2012 and RB711. Restarting every 5minutes. In log is - Router was rebooted without proper schutdown.
With 5.17 uptime a lot of days
Sounds like watchdog. Uncheck the watchdog timer and see if that fixes it.
