eth port speedcheck
Hi all, i need a small script, what check ports speed, if it was 1g and if it was goes down too 100m restart autonack or complete port to get up to gbit, can anybody help please?
regards
“restarting” a port doesn’t fix the “why” it got down to 100Mbps, from 1Gbit. Fix your loose connections.
Hi is a PoE before and if it was very hot and 72Volt are in PoE Port on PoE flapp and goes doen to 100M i mean. Well cable and grounding are ok.
Using The Dude, add a new probe like:
With OID:
iso.org.dod.internet.mgmt.mib-2.interfaces.ifTable.ifEntry.ifSpeed.1
Some routers will have a different OID. For example, HAP AC2 uses
 iso.org.dod.internet.mgmt.mib-2.interfaces.ifTable.ifEntry.ifSpeed.3
for port 1
Add the probe to the device
thank you for sharing
