Greetings!
CCR1016-12G, 6.15
Seems that my problem is simple, but i can’t untersand, where I wrong.
My config:
add name=bridge-main
/interface vrrp
add interface=ether5 name=vrrp1 priority=250 v3-protocol=ipv6 vrid=4
/interface vlan
add interface=vrrp1 name=vlan1 vlan-id=1
add bridge=bridge-main interface=vlan1
add bridge=bridge-main interface=ether6
As result, I get that map
ether5
-> vrrp
->vlan1-in-bridge
ether6-in-bridge
Then I connect test device to ether6, connect my machine to trunked port ether5, and try to ping test device.
If I don’t use vrrp - everything fine, ping 100% success.
If I don’t use L2 bridging, just use L3 routing
#my machine 10.1.1.99/24 default gw 10.1.1.100
#test device 10.10.10.10/24 default gw 10.10.10.1
add disabled=yes name=bridge-main
add bridge=bridge-main disabled=yes interface=vlan1
add bridge=bridge-main disabled=yes interface=ether6
/interface vrrp
/interface vlan
add interface=vrrp1 name=vlan2 vlan-id=6
add address=10.10.10.1/24 interface=vlan2 network=10.10.10.0
add address=10.1.1.100/24 interface=vlan1 network=10.1.1.0
everything work fine too (include vrrp) - ping ok!
If I But when I try to use vrrp AND vlan in bridge - nothing! No ping, no data, only despair and nothing more.
Please, tell me, what im doing wrong?
