We deploy a lot of microtiks and we’ve been noticing about 25% of the ones we try to deploy have an issue where port 1 autonegotiates to 100mbps without reason.
crs109-8g
RouterOS 6.34
Firmware 3.24
Using them in a layer 2 fiber network where we sometimes want to run poe and data in on eth1 then we just bridge to the vlan. All the boxes are checked for all the speeds, but the rate limits to 100mbps.
We just find on the poe installs, half the time the installer tests them and they can’t do gbps speeds.
Is this a bug, feature or config error?
Any assistance would be helpful, we have a lab setup to test this and we have been able to reproduce it on several devices.
edit: we confirmed the issue does not exist on default config, so it’s something in our config. the eth1 port is set to bg and then assigned to a bridge, im going to be looking around there, any ideas would be helpful thanks.
We’ve reproduced this in the lab without injector, we also could not reproduce it on a default tik and the issue presented happened after configuration was applied.
It’s happened on so many devices they can’t all have bad cables also.
All of our config is just create eth 1, create bridge, create vlan, assign them to each other, they are all set to gbit.
Any issue with port speed negotiation would only be in the physical interface configuration itself, and not have anything to do with bridge/routing configurations.
FYI - you might want to make this command part of your standard installation:
/int eth reset-mac-address [find]
… unless you specifically wanted to use those MAC addresses instead of the ones built into the hardware.
But those settings shouldn’t interfere with speed/duplex negotiation.
Just for laughs, what happens if you power the device with PoE but plug the ethernet into the other gig ports (2-5) - do those work?
New information came to light, we were able to reproduce it without any power injector.
To review, gigabit interfaces plugged into eth1 on a tik are autonegotiating to 100Mbps instead of 1Gbps. (as seen in Winbox if you add the 'rate' column, which is not easy because it drops off the screen in the drop down selector)
So on same tik, with our default configuration(ill export whole conf below) the following tests were run with same cables.
macbook pro Gb to port 1 - 1Gbps
thinkpad Gb to port 1 in windows 10 - 1Gbps for 10 seconds then drops to 100
thinkpad Gb to port 1 in ubuntu - 1Gbps for 10 seconds then drops to 100
linksys ea4500 to port 1 - 1Gbps
all four of these to port 3 - 1Gbps
This rules out cable and OS, narrows it to just port 1.
Theory: Something about the thinkpad nic and the other nics/ports we use it with, like lightning edges and brocades, does not interface well with the tik's interface.
Can anyone reproduce this besides me? It is happening with a lot of our devices.
In the interface eth1 menu, autoneg is on, bandwidth isn't limited, flow control isn't on and all the advertise boxes are checked.
Any ideas? What other conditions could we test?
export:
feb/25/2016 13:20:11 by RouterOS 6.34
software id = YBJJ-GYC5
add mtu=1500 name=1001.br
add mtu=1500 name=bridge1
add mtu=1500 name=mgmt.br
/interface wireless
set [ find default-name=wlan1 ] name=wlan4
set [ find default-name=ether1 ] comment="Customer (xxx-xxx-xxxx)"
mac-address=4C:5E:0C:A5:1C:1A
set [ find default-name=ether2 ] arp=disabled mac-address=4C:5E:0C:A5:1C:1B
set [ find default-name=ether3 ] mac-address=4C:5E:0C:A5:1C:1C
set [ find default-name=ether4 ] mac-address=4C:5E:0C:A5:1C:1D
set [ find default-name=ether5 ] mac-address=4C:5E:0C:A5:1C:1E
set [ find default-name=ether6 ] mac-address=4C:5E:0C:A5:1C:1F
set [ find default-name=ether7 ] mac-address=4C:5E:0C:A5:1C:20
set [ find default-name=ether8 ] mac-address=4C:5E:0C:A5:1C:21
set [ find default-name=sfp1 ] comment="Service Address" mac-address=
4C:5E:0C:A5:1C:22
/ip neighbor discovery
set ether1 comment="Customer (xxx-xxx-xxxx)"
set sfp1 comment="Service Address"
/interface vlan
add interface=sfp1 name=1001.sfp vlan-id=1001
add interface=sfp1 name=mgmt.sfp vlan-id=85
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
/snmp community
set [ find default=yes ] name=lcpubnkc
add addresses=0.0.0.0/0 name=lcprinkc write-access=yes
add addresses=0.0.0.0/0 name=lcprids write-access=yes
/system logging action
set 3 remote=xxxx src-address=xxxx
add bridge=bridge1
add bridge=1001.br interface=1001.sfp
add bridge=1001.br interface=ether1
/ip dhcp-client
add dhcp-options=hostname,clientid interface=bridge1
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no
interface=mgmt.sfp
/lcd
set default-screen=stats enabled=no read-only-mode=yes time-interval=hour
touch-screen=disabled
/lcd pin
set pin-number=1313
/snmp
set contact="Name and Number" enabled=yes location=Address trap-community=
lcprids trap-version=2
/system clock
set time-zone-autodetect=no time-zone-name=xxxxxx
/system identity
set name=xxxxxx
/system logging
set 0 disabled=yes
add action=remote disabled=yes topics=backup
add action=remote disabled=yes topics=account
add action=remote topics=error
add action=remote topics=critical
add action=remote topics=interface
add action=remote topics=warning
add action=remote disabled=yes topics=ssh
/system ntp client
set enabled=yes primary-ntp=x.x.x.x secondary-ntp=x.x.x.x
Bought CRS112-8P-4S ( 2022.02 ) and have the same problem on eth port 1 auto-negotiates to 100Mb. Other ports are working fine. Using RouterOS 6.48.6. So seems like this problem is still present.
