I am after some guidance.
Basically I am unable to connect my router: MikroTik RB5009UPr+S+IN
to ISP’s network.
ISP’s requirements:
“You basically need to provision the WAN/Internet interface for IP over Ethernet.
Second requirement is that VLAN tagging needs to be enabled on the interface and set to vlan 911.
Third requirement is that the interface IP needs to be set to DHCP. That way it automatically gets assigned an IP from our DHCP server.”
My config (it seems that I cannot get an address from DHCP):
I would appreciate if someone would help me to get my router connected. Thanks
Do you have any firewall rules that might block?
anav
April 25, 2024, 8:45pm
3
You need to go to IP DHCP client next…
and select vlan 911 as the interface ( not vlanfiber! )
vlanfibre is a vlan created and set to vlan 911 the only other option I have is Fiber_eth1, I cannot add vlan 911 as you mentioned in DHCP client?
Even when I switch dhcp client up to Fiber_eth1,same issue it does not seem to get and address
Can you advise further? sorry
Amm0
April 26, 2024, 12:42am
5
The 1st requirement is kinda odd: “IP over ethernet”. If that mean PPPoE (or perhaps Mikrotik specific EoIP?) that be different story, but I presume they just mean it has VLAN. But step 1 is an odd way to state a requirement.
One thing might help here, is if you can use /tool/torch on the fiber or VLAN, and just see what kinda of packets are flowing over the line and/or what VLAN they appear.
Does not seem like there is anything that could block it?
Amm0
April 26, 2024, 12:45am
7
Did you add “vlanfiber” VLAN interface as a LAN in /interface/list?
Amm0
April 26, 2024, 1:04am
9
Yeah I meant WAN. So that’s right.
Try the ether1 in torch, to see if you getting any traffic from upstream. The torch above shows your dhcp-client looking for an address on VLAN 911.
Might want to post your config too. In terminal, :export file=config.rsc then download from Files.
ether1 results in torch:
config:
# apr/26/2024 02:08:43 by RouterOS 7.8
# model = RB5009UPr+S+
add admin-mac=********** auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=Port1 name=Fiber_eth1
/interface vlan
add interface=Fiber_eth1 name=vlanfiber vlan-id=911
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add comment=defconf interface=vlanfiber list=WAN
192.168.88.0
/ip dhcp-client
add interface=vlanfiber
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/tool mac-server
/tool mac-server mac-winbox
Amm0
April 26, 2024, 1:33am
11
This all looks right. The odd thing is that it does look like the ISP thinks your IP is 10.2.118.106 on VLAN 911.
You’re running an older version. And I want to say some version had some bug in dhcp-client around that time.
You may want to download latest stable release, and copy it to the root of Files, then reboot:
https://download.mikrotik.com/routeros/7.14.3/routeros-7.14.3-arm64.npk
After the update torch results:
config:
# 2024-04-26 02:38:02 by RouterOS 7.14.3
add admin-mac=********** auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
# poe-out status: short_circuit
/interface vlan
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/ip smb users
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether8 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=sfp-sfpplus1 internal-path-cost=\
10 path-cost=10
set udp-timeout=10s
192.168.88.0
/ip dhcp-client
192.168.88.1
/ip dns static
invalid
/ip smb shares
set [ find default=yes ] directory=/pub
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/system clock
/system note
set show-at-login=no
/tool mac-server
I am at a bit of a loss, it’s never easy…
Amm0
April 26, 2024, 2:06am
13
Maybe disable PoE on ether1? e.g. you have this message:
Possible that interfering with the traffic, since your not getting anything back (or at least only a few packets).
Can also look at Logs, and see if anything there has errors/warning.
But I’m kinda out of suggestions here. Maybe someone else has an idea here.
Disabled it, rebooted the router - error disappeared
did another torch scan:
I hope someone can help, I raised this with ISP too, will see what they say as I am out of ideas
Amm0
April 26, 2024, 2:27am
15
I supose you can try disabling the “input” firewall filter rule with “drop” and “!LAN” & see if you get a DHCP address after that.
If that works, then you might have to allow DHCP from the VLAN 911 to the firewall to allow it I guess.
And/or, just assign the IP address it’s showing torch as an /ip/address for the VLAN. e.g.
/ip/address/add interface=vlanfiber address=10.2.118.106/24
Then see if /ping 10.2.118.1 works from RouterOS Terminal?
Disabled the “input” firewall filter rule with “drop” and “!LAN” & rebooted the router, did not get DHCP address after that
I assigned the IP address, does not seem to ping:
sent=180 received=0 packet-loss=100%
SEQ HOST SIZE TTL TIME STATUS
180 10...... timeout
181 10....... timeout
182 10....... timeout
183 10....... 84 64 31ms535us host unreac...
sent=200 received=0 packet-loss=100%
Amm0
April 26, 2024, 3:05am
17
Okay, that all I got. I was guessing at the default gateway, and it’s unclear why touchthe dst-addr of 10.x.x.x
Is there a modem to reboot? But I think you’re going to have to confirm with your ISP the needed settings. As I said, the first step “IP over ethernet” is just pretty vague.
Am I missing PPPoe settings or set up on the router? can they use PPPoe without a username and password? would I have to potentially clone the MAC address of the ISP’s router on my Mikrotik router (if that’s even possible)? as I assume they would have provided it when I contacted them regarding router set-up…
as I have seen this forum post of someone setting up a tp-link router same provider they seem to have a similar issue https://forums.thinkbroadband.com/fibre/4740572-gigabit-networks-installing-3rd-party-router.html?vc=1
I have contacted the ISP again for clarification and support, but if anyone else has any ideas I would appreciate your support. Thanks
Amm0
April 26, 2024, 4:18am
19
Yeah, they may need to know your MAC address. You can “clone it” but simply entering your old router’s MAC address on the ether1 interface, obviously your older router have be unplugged after.
Cloning MAC address of ISP’s router did not work, still seems to be doing the same thing where it does not pick up IP from DHCP, still waiting for a response from ISP…
