ETHE1 traffic fully forwarded
hi
I’m kind of new to mikrotik device config and it seems a bit complex to me.
I have LTE router with mobile internet coming in as WAN and i need it to either pass all traffic on ETHE1 port untouched.
or set it as DMZ mode as on other brand routers where it works as bridge that just simply forwards all, including WAN IP to next device, this option i prefer not to use as i loose 4 remaining ETHE ports on Mikrotik router that i could use.
had that DMZ setup working before on huawei router with no problems but had to upgrade to mikrotik now.. and having problems to configure..
but would love to know how to set up both options incase just forwarding traffic wont work.
on ETHE1 is connected VPN device with firewall that then passes traffic to next router that has its own firewall.. so no worries about security.
please someone help.
check this
Passthrough Example
https://help.mikrotik.com/docs/display/ROS/LTE#LTE-PassthroughExample
after 2nd command getting this:
failure: Passthrough interface can not be slave!
