ether link down in Hap AC
Labrit !
i have new Hap AC.
I connected my IMac directly to Hap.
So port’s 3 and 5 regular connected/disconected
03:30:12 interface,info ether5 link down
03:30:14 interface,info ether5 link up (speed 1G, full duplex)
03:31:07 interface,info ether5 link down
03:31:09 interface,info ether5 link up (speed 100M, full duplex)
05:31:04 interface,info ether5 link down
05:31:06 interface,info ether5 link up (speed 1G, full duplex)
05:31:59 interface,info ether5 link down
05:32:00 interface,info ether5 link up (speed 100M, full duplex)
on Port 4 everything ok ! (Rate 1Gbps) and no link down
This is HW fault ?
I had the same problems with hAP lite rb941. Example port 3 only for one laptop did not work, all other ports ok, and port 3 for other computers ok, even two same 8440p elitebooks one worked on ether 3 other not, and the same laptop that did not work on rb941 worked on any other equipment, when replaced rb941 worked on all ports the same laptop that did not worked on frist rb941. Same RouterOS on both hAP lite, didnt have much time to go in detailed diagnostic, just wanted you to know.
Try another device on those ports that you have problems.
So i guess is some strange hardware failure
this is main idea, just to return this device.
