Ether1 dont allow connection from outsite
I have an 3011RB router with 2 WANs that have instaleld v 6.38.1
I configured more than 3 months ago and everything was ok until 2 days ago when I restarted the router.
Now on interface 1 i have a strange issue: The interface don’t allow connection from internet.
I tried to debug and until now i don’t figure out what can have.
  • Router get IP on ether1.
  • From Tools-> Ping i can ping through interface 1 with success
  • From outside the router don’t resound to ping and dont accept any new connection . (I cannot connect to windbox and other ports foarwarded - connection timeout issue )
  • I tried to debug PING. I observe that i receive package but the router don’t transmit (TX = 0)
  • I disable all firewalls rules that drop the backage and the router dont resound at ping. (ICMP rule is active)
The firewall config is :
 0 XI  chain=input action=accept in-interface=ether1-gemenii log=yes log-prefix=>
 1    ;;; accept ICMP
      chain=input action=accept protocol=icmp in-interface-list=WANs log=no
      log-prefix=""
 2    ;;; accept establieshed,related
      chain=input action=accept connection-state=established,related log=no
      log-prefix=""
 3    ;;; Allow WinBox from outside - Gemenii
      chain=input action=accept protocol=tcp in-interface=ether1-gemenii
      dst-port=8291 log=no log-prefix=""
 4    ;;; Allow WinBox from outside -telekom
      chain=input action=accept protocol=tcp in-interface=ether2-telekom
 5 XI  ;;; Allow HTTP from outside
      dst-port=80 log=no log-prefix=""
 6    ;;; accept established,related
      chain=forward action=accept connection-state=established,related log=no
      log-prefix="filter_Rules"
 7 XI  ;;; fasttrack
      chain=forward action=fasttrack-connection
      connection-state=established,related log=no log-prefix=""
 8    ;;; drop ssh brute forcers
      chain=input action=drop protocol=tcp src-address-list=ssh_blacklist
      dst-port=22 log=no log-prefix=""
 9    chain=input action=add-src-to-address-list connection-state=new
      protocol=tcp src-address-list=ssh_stage3 address-list=ssh_blacklist
      address-list-timeout=1w3d dst-port=22 log=no log-prefix=""
10    chain=input action=add-src-to-address-list connection-state=new
      protocol=tcp src-address-list=ssh_stage2 address-list=ssh_stage3
      address-list-timeout=1m dst-port=22 log=no log-prefix=""
11    chain=input action=add-src-to-address-list connection-state=new
      protocol=tcp src-address-list=ssh_stage1 address-list=ssh_stage2
12    chain=input action=add-src-to-address-list connection-state=new
      protocol=tcp address-list=ssh_stage1 address-list-timeout=1m dst-port=22
13 XI  ;;; LOG Write
      chain=output action=accept protocol=icmp out-interface=ether1-gemenii
      log=yes log-prefix="icmp_output"
14    ;;; drop all from WAN
      chain=input action=drop in-interface=ether1-gemenii log=no log-prefix=""
15    ;;; drop invalid
      chain=forward action=drop connection-state=invalid log=no log-prefix=""
16    ;;;  drop all from WAN not DSTNATed
      chain=forward action=drop connection-state=new
Thank you
You have a catch-all drop rule, which is enabled:
chain=input action=drop in-interface=ether1-gemenii log=no log-prefix=“”
Thank you very much Normis .
I have a question : why when i disabled the rules with drop the router didn’t react ? I observe that on restart the router takes the modification from Filter Rules. I have to load manually the rules or just restart reload the firewall rules ? (To write in console something like /firewall rules “aotoload” (this option is not available). Or maybe disable rule one by one with “Apply and Ok”.
When connection is already opened, your “new” rules will not apply, the connection is no longer new. You have to force it to drop. This is why you can make rules also for established connections.
