ether1 interface is not working/
Hey everyone,
I have this problem where after initial default setup the ether1 interface is not working or offline or i dont know …
it does get recognized and it is enabled though it doesnt get any signal.
on the DHCP-client it says status ‘stopped’
on the interface panel, there isnt a R or S or D
what I tried:
internet and patch cables work on old router.
i assigned the wan port(ether1) to port2,3,4,sfp to check if by any chance port1, and sfp(module), were broken, - none of them works with wan but as a lan port everything is ok
everything is kept at default
# jan/02/1970 00:03:33 by RouterOS 6.49
# software id = 0I66-QYFR
# model = RB760iGS
# serial number =
add admin-mac=64:4C:58:F0:9D:B6 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/tool mac-server
/tool mac-server mac-winbox
Sounds like an ISP or ISP modem issue, config looks okay.’
You will have to explain your WAN connection ISP info in more detail.
Thats what i thought. It sounds like they use some mac filtering.
