thanks for your reply.
Im running all devices on 7.19.1
I’ll post the configuration from my CAPsMAN:
add admin-mac=xxxx auto-mac=no frame-types=admit-only-vlan-tagged name=BR-MAIN protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] name="ether1 - WAN" poe-out=off
set [ find default-name=ether2 ] name="ether2 - AP1"
set [ find default-name=ether3 ] name="ether3 - AP2"
set [ find default-name=ether4 ] name="ether4 - Printer" poe-out=off
set [ find default-name=ether5 ] name="ether5 - Zigbee"
set [ find default-name=ether6 ] disabled=yes poe-out=off
set [ find default-name=ether7 ] name="ether7 - Home Assistant"
set [ find default-name=ether8 ] name="ether8 - Office" poe-out=off
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface vlan
add interface=BR-MAIN name=VLAN10_WIFI vlan-id=10
add interface=BR-MAIN name=VLAN20_IOT vlan-id=20
add interface=BR-MAIN name=VLAN50_MGMT vlan-id=50
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi channel
add disabled=no frequency=2412 name="CH 1 (2412)" width=20mhz
add disabled=no frequency=2437 name="CH 6 (2437)" width=20mhz
add disabled=no frequency=2462 name="CH 11(2462)" width=20mhz
add disabled=no frequency=5180 name="CH 36 (5180)" width=20/40/80mhz
add disabled=no frequency=5260 name="CH 52 (5260)" width=20/40/80mhz
add disabled=no frequency=5500 name="CH 100 (5500)" width=20/40/80mhz
add disabled=no frequency=5680 name="CH 136 (5680)" width=20/40/80mhz
add disabled=no frequency=5745 name="CH 149 (5745) SRD" width=20/40/80mhz
/interface wifi datapath
add bridge=BR-MAIN disabled=no name=DP_WIFI vlan-id=10
add bridge=BR-MAIN disabled=no name=DP_IOT vlan-id=20
/interface wifi security
add authentication-types=wpa2-psk disabled=no encryption="" ft=yes ft-mobility-domain=0x100 ft-over-ds=yes name=SEC_WIFI wps=disable
add authentication-types=wpa2-psk disabled=no ft=no ft-over-ds=no name=SEC_IOT wps=disable
/interface wifi configuration
add channel="CH 36 (5180)" channel.skip-dfs-channels=all country=Austria datapath=DP_WIFI disabled=no name=WIFI-AP1-CH36 security=SEC_WIFI security.ft-preserve-vlanid=yes ssid=Owcahome
add channel="CH 52 (5260)" channel.skip-dfs-channels=10min-cac country=Austria datapath=DP_WIFI disabled=no name=WIFI-AP2-CH52 security=SEC_WIFI security.ft-preserve-vlanid=yes ssid=Owcahome
add channel="CH 1 (2412)" channel.skip-dfs-channels=all country=Austria datapath=DP_IOT disabled=no name=IOT-AP1-CH1 security=SEC_IOT ssid=IoT
add channel="CH 6 (2437)" channel.skip-dfs-channels=all country=Austria datapath=DP_IOT disabled=no name=IOT-AP2-CH6 security=SEC_IOT ssid=IoT
add name=POOL_WIFI ranges=10.10.10.2-10.10.10.254
add name=POOL_MGMT ranges=10.10.50.2-10.10.50.254
add name=POOL_IOT ranges=10.10.20.2-10.10.20.254
add address-pool=POOL_WIFI interface=VLAN10_WIFI lease-time=1d name=DHCP_WIFI
add address-pool=POOL_MGMT interface=VLAN50_MGMT lease-time=1d name=DHCP_MGMT
add address-pool=POOL_IOT interface=VLAN20_IOT lease-time=1d name=DHCP_IOT
add bridge=BR-MAIN comment="AP Kitchen" frame-types=admit-only-vlan-tagged interface="ether2 - AP1"
add bridge=BR-MAIN comment="AP Playroom" frame-types=admit-only-vlan-tagged interface="ether3 - AP2"
add bridge=BR-MAIN comment="Printer" frame-types=admit-only-untagged-and-priority-tagged interface="ether4 - Printer" pvid=20
add bridge=BR-MAIN comment="Zigbee Gateway" frame-types=admit-only-untagged-and-priority-tagged interface="ether5 - Zigbee" pvid=20
add bridge=BR-MAIN comment=unused disabled=yes interface=ether6
add bridge=BR-MAIN comment="Home Assistant" frame-types=admit-only-untagged-and-priority-tagged interface="ether7 - Home Assistant" pvid=20
add bridge=BR-MAIN comment=Office frame-types=admit-only-untagged-and-priority-tagged interface="ether8 - Office" pvid=10
set discover-interface-list=none
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=BR-MAIN comment=Management tagged="BR-MAIN,ether2 - AP1,ether3 - AP2" vlan-ids=50
add bridge=BR-MAIN comment=IoT tagged="BR-MAIN,ether2 - AP1,ether3 - AP2" untagged="ether4 - Printer,ether5 - Zigbee,ether7 - Home Assistant" vlan-ids=20
add bridge=BR-MAIN comment=Main tagged="BR-MAIN,ether2 - AP1,ether3 - AP2" untagged="ether8 - Office" vlan-ids=10
add comment=defconf interface=VLAN10_WIFI list=LAN
add comment=defconf interface="ether1 - WAN" list=WAN
add interface=VLAN20_IOT list=LAN
add interface=VLAN50_MGMT list=LAN
add interface=VPN list=LAN
/interface wifi capsman
set ca-certificate=auto certificate=auto enabled=yes interfaces=VLAN50_MGMT package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled comment="5 GHZ WIFI - AP1 CH36" disabled=no master-configuration=WIFI-AP1-CH36 name-format=Wifi-%I radio-mac=xxx slave-configurations="" supported-bands=5ghz-ax
add action=create-dynamic-enabled comment="2.4 GHZ IOT - AP1 CH1" disabled=no master-configuration=IOT-AP1-CH1 name-format=IoT-%I radio-mac=xxx slave-configurations="" supported-bands=2ghz-g
add action=create-dynamic-enabled comment="5GHZ WIFI - AP2 CH100" disabled=no master-configuration=WIFI-AP2-CH52 name-format=Wifi-%I radio-mac=xxx supported-bands=5ghz-ax
add action=create-dynamic-enabled comment="2.4GHZ - AP2 CH6" disabled=no master-configuration=IOT-AP2-CH6 name-format=IoT-%I radio-mac=xxx supported-bands=2ghz-g
add address=10.10.10.1/24 interface=VLAN10_WIFI network=10.10.10.0
add address=10.10.20.1/24 interface=VLAN20_IOT network=10.10.20.0
add address=10.10.50.1/24 interface=VLAN50_MGMT network=10.10.50.0
add address=10.10.99.1/24 comment=VPN interface=VPN network=10.10.99.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=10m
/ip dhcp-client
add address=10.10.10.0/24 gateway=10.10.10.1
add address=10.10.20.0/24 gateway=10.10.20.1
add address=10.10.50.0/24 gateway=10.10.50.1
set allow-remote-requests=yes cache-size=20480KiB mdns-repeat-ifaces=VLAN10_WIFI,VLAN20_IOT
/ip dns adlist
add ssl-verify=no url=https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=10.10.10.0/24 list=Wifi
add address=10.10.20.20 list=SONOS
add address=10.10.20.21 list=SONOS
add address=10.10.20.22 list=SONOS
add address=10.10.20.23 list=SONOS
add address=10.10.20.24 list=SONOS
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input comment="Allow Wireguard" dst-port=31337 protocol=udp
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward comment="Wifi LAN to Sonos" dst-address-list=SONOS dst-port=1400,3400,3401,3500,4070,4444 port="" protocol=tcp src-address-list=Wifi
add action=accept chain=forward comment="Wifi LAN to Sonos (UDP)" dst-address-list=SONOS dst-port=1900,1901,2869,10243,10280,5353,6969 protocol=udp src-address-list=Wifi
add action=accept chain=input comment="Allow mDNS" dst-address=224.0.0.251 dst-port=5353 log-prefix=mDNS protocol=udp src-port=5353
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www-ssl disabled=no
set api address=10.10.20.2/32
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/ip upnp interfaces
add interface=VLAN10_WIFI type=internal
add interface=VLAN20_IOT type=internal
/ipv6 firewall address-list
/system clock
set time-zone-name=Europe/Vienna
/system logging
set 0 topics=info,!wireguard
add topics=wireless,info
add topics=debug,poe-out
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
in the meantime, I removed the wifi interfaces from the bridge on the CAP, and adjusted the VLAN filtering (only admit tagged traffic whenever its necessary) on Capsman and Cap - still not working properly. When I enable VLAN filtering on CAP Bridge, clients no longer receive a DHCP lease. I stay connected on cap, and tagged/untagged is populated on bridge. Maybe just don’t see it
CAP (AP2) config:
add admin-mac=xxx auto-mac=no name=BR-MAIN
set [ find default-name=ether1 ] name="ether1 - Router"
set [ find default-name=ether2 ] disabled=yes name="ether2 - Sonos" poe-out=off
/interface vlan
add bridge=BR-MAIN disabled=no name=DP_MAIN
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.manager=capsman .mode=ap .ssid=MikroTik-F8B834 datapath=DP_MAIN disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz configuration.manager=capsman .mode=ap .ssid=MikroTik-F8B835 datapath=DP_MAIN disabled=no security.authentication-types=wpa2-psk,wpa3-psk
add bridge=BR-MAIN interface="ether2 - Sonos" pvid=20 frame-types=admit-only-untagged-and-priority-tagged
add bridge=BR-MAIN frame-types=admit-only-vlan-tagged interface="ether1 - Router"
set udp-timeout=10s
/ipv6 settings
add bridge=BR-MAIN comment="Trunk Port" tagged="ether1 - Router,BR-MAIN" vlan-ids=10,50
add bridge=BR-MAIN comment=Sonos tagged="BR-MAIN,ether1 - Router" untagged="ether2 - Sonos Playroom" vlan-ids=20
add interface=BR-MAIN list=LAN
/interface wifi cap
set discovery-interfaces=VLAN50_MGMT enabled=yes slaves-datapath=DP_MAIN
/ip dhcp-client
/system clock
/system identity
set name=AP2
/system leds settings
set all-leds-off=immediate
/system routerboard mode-button
set on-event=dark-mode
/tool mac-server
/tool romon
set enabled=yes
