ether3 status
Good Day
I need some help configuring a scrip to run i want it to do the following
Constantly monitoring an ether port if the ether port status gos to Link-ok to no-link then i want to be notified via an email
please help
RB750 from V4 to V6
Regards Gideon
you modify a bit…
#Ethernet Port Mode Monitoring
/system scheduler add disabled=no interval=12h start-time=startup name=Ethernet_Port_Mode_Monitor on-event=“/interface ethernet monitor ether1 once do={:if ($rate !="100Mbps") do={/system script run Ethernet_Port_Monitoring}}”
:if ([system script find name=“Ethernet_Port_Monitoring”] =“”) do={/system script add name=Ethernet_Port_Monitoring source=“:delay 5s\r\n/tool e-mail send server=10.5.50.11 to=alert@xxx.net from=system@xxx.net subject="$[/system identity get name] $[/system clock get time] $[/system clock get date]" body="message from $[/ip address get value-name=address number=0] - The system detected Ethernet is 10BaseT now, Please check and take note…"”}
