Good day,
I recently noticed an increase of bandwidth on my sectors.
About 1-3 Mbps exstra with some clients, even when queuing the wlan interface.
This is an example from one client.
rx-packets-per-second: 192 270
rx-bits-per-second: 150.6kbps 2.9Mbps
fp-rx-packets-per-second: 192 270
fp-rx-bits-per-second: 150.6kbps 2.9Mbps
rx-drops-per-second: 0 0
rx-errors-per-second: 0 0
tx-packets-per-second: 191 185
tx-bits-per-second: 2.0Mbps 290.1kbps
fp-tx-packets-per-second: 191 0
fp-tx-bits-per-second: 2.0Mbps 0bps
tx-drops-per-second: 0 0
tx-errors-per-second: 0 0
As jou can se the rx bits per second on the top(wlan) and the tx at the bottom has about 1Mbps difference.
The network is routed and the wlan ip’s is private. so allow remote dns requests is not a culprit this time.
Any insight on the problem will be appreciated.
Thank you
