Good day!
I have a problem.
i have router mikrotik hap ac
Ethernet(Intranet) clients do not see each other!!! But they have access to gateway and internet
/export compact
jan/02/1970 00:51:03 by RouterOS 6.40
software id = 126L-38HA
model = RouterBOARD 962UiGS-5HacT2HnT
serial number = 6F1207075AA4
add name=bridge-local
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master name=ether3-slave
set [ find default-name=ether4 ] master-port=ether2-master name=ether4-slave
set [ find default-name=ether5 ] master-port=ether2-master name=ether5-slave
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-wan name=
pppoe-rostelecom password=szt use-peer-dns=yes user=szt
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=ap-bridge
ssid=zhopanet
set [ find default-name=wlan2 ] band=5ghz-a/n/ac disabled=no mode=ap-bridge
ssid=zhopanet5
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=
dynamic-keys wpa2-pre-shared-key=zhopaleo
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.254
add address-pool=dhcp_pool0 disabled=no interface=bridge-local name=dhcp1
add bridge=bridge-local interface=ether2-master
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=wlan2
add address=192.168.88.1/24 interface=bridge-local network=192.168.88.0
add address=192.168.88.0/24 gateway=192.168.88.1
add action=drop chain=input in-interface=pppoe-rostelecom
add action=masquerade chain=srcnat out-interface=pppoe-rostelecom
