Ethernet errors
I was wondering on either 2.8 or rc9 is there a place to check on ethernet errors (FCS’s, shorts, etc). Mabe I’m overlooking things, but I can’t seem to find them. My question would be can you view ethernet errors with either release? And if so, where is it on gui/terminal.
Eric
I think the only way to see these is with SNMP…
Ugh, ok. I guess that would be a good request for any future releases. It would be very nice to be able to easily see the eth errors incrementing if there was a cable/hub/switch problem.
Eric
It’s been requested, it just doesn’t appear to be a high priority.
