I’ve experienced many failures on wireless CPE/AP ethernet ports. The problem shows up going through different steps:
ethernet port stops working at 100Mbps/Full duplex but still work at 10 Mbps full/half dubplex
few days after step 1) the port stops working at all, stuck in down state (interface apeears not Registered in winbox).
It looks like routerboard are a little weak on ethernet hardware.
Anyone experiencing the same problem? How could I workaround ? Any trick in intallation phase to help saving the hardware (particular grounding, shielding, … )?
The most common cause for this is the quality of connectors and their crimping. Replace connectors with new ones and give a try. If you are sure they are fine and it is still happening, you probably have a faulty device connected to the other side of mikrotik. It has happened many times for me and it never was routerboard’s fault. PoE has nothing to do with this.
Thanks for your answers, still have some doubts: what do you mean for splitting out poe + data? Use 1 ethernet port just for poe and another one for data?
What if my device just has 1 ethernet port (i.e. wireless cpe) ? May you suggest me some DC protection products?
Have you ever tried to use shielded FTP cable with shielded connectors, and a GROUNDED PoE ? For example the 15V or 24V from Ubiquiti works perfect for me.
