ethernet issue
Hello everybody.
My question is how I set long-cable= yes in winbox:
long-cable (yes | no; default: no) - changes the cable length setting (only applicable to NS DP83815/6 cards). For cable lengths of more than 50m, set “long-cable=yes”
Please need help.
You have to open a terminal window and type in the command from the command line:
[admin@mt] interface ethernet> set 2 cable-settings=?
Ethernet cable type
CableSettings ::= default | standard | short
Note, that from a command line, you can use the “?” to find available commands and settings for a particular device or section. If you play around with it a little you’ll realize it’s really not that bad.
Thanks Jarosoup
