Thanks in advance for whom replies to this posting. I have 300 mikrotiks and every other day I have a random RB that the ethernet would stop responding. If I disable the ethernet port and reenable it. Then it starts working. That works every time. I have tried these versions of routeros with the same results(4.3/4.5/4.6/4.10/4.11). Each time I upgraded the routerboard bios to that version. I am going to try version 3.30 and 5.0beta5. I have replaced all hardware including the ethernet cables and POE twice. Is anyone else seeing this problem? Mikrotik support do you have anything else that I could try?
Topology:
Core router (main dhcp server with eoip tunnels to the access points)
Underneath the eoip is OSPF.
