Ethernet PC Cards
Greetings,
I am experimenting with my first RouterBoard, and I am wondering if it is possible to use a PCMCIA(PC Card) ethernet port on them to take it from 2 to 3 Ethernet interfaces. If so, any suggestions as to make/model, and how to go about enabling it once it is in place.
Thanks,
Dain
I had D-Link DE-660 and it worked. Some others also may - see the Device Driver List and search for PCMCIA or CardBUS
Where do I find the list you mentioned?
In the MikroTik documentation, where else:
http://www.mikrotik.com/docs/ros/2.8/
(for the DDL: http://www.mikrotik.com/docs/ros/2.8/guide/driverlist.frameset )
