Hi, I have RB433 (GL and AH), both ROs 6.2.
I assign IP address to ether1 port, then use ether2 and ether3 as switch.
So I set ether2 and ether3 with ether1 as master port.
Is this correct?
Now on RB433GL I see:
switch → name = switch1, Type= unknown
port → ether1, ether2, ether3, switch1 cpu
On RB433AH I try to do the same:
switch → name = switch1, Type= IC Plus 175D
port → ether2, ether3, switch1 cpu
if I try to set ether2 or ether3 master port=ether1 I get error:
failure: master-port must be in same switch group
Why if all settings are the same?
Why first RB ether1 belongs to switch group 0 while second RB ether1 not?
thanks.
