Hi guys,
i have purchased a Nexcom DN1110 embedded system with four 82801H (ICH8 Family) pci-express ethernet ports, and I have installed RouterOS Ver 4.10 for x86 system. Problem is that I don’t see any ethernet port on RouterOS interface.
I think because RouterOS doesn’t have driver installed: is it possible? How could I install it?
There is no option to install any driver at MikroTik RouterOS.
I would recommend to try the latest 5.0beta4 version, which uses the latest drivers.
Maybe card is supported there.
Perfect! With routerOS 5.0 beta4 now I see all 4 ethernet interfaces.
But I have another problem: if I configure an IP address for each interface and i connect a pc, I have a ping reply only from ether4 and not from ether1, ether2 and ether3: why?
