Ethernet router for LAN (30 PCs)
I ma looking for ethernet router for LAN (about 30 PCs, neighborhood network, 200 Mb/s / 200 Mb/s).
It will not be doing the advanced firewall, only some qos rules.
Which RouterBOARD hardware should be suitable?
Thank you in advance.
Mikrotik Hex
https://routerboard.com/RB750Gr3
Gigabit, cheap, it’ll handle the load.
Take the new hEX or RB3011 of you need a 19" Version.
Thanks for advice.
