Ethernet test result
Hi there!
In each routerboard information page there is Ethernet test result section at the end of the page. I was wondering what information it represents and how I can use it .
Have you read information under these tables ? And descriptions of rows an columns ?
Yes but I can’t understand it.
for example can you explain this row please:
Mode Configuration 1518 byte 512 byte 64 byte
kpps Mbps kpps Mbps kpps Mbps
Bridging none (fast path) 161.9 1,966.1 345.5 1,415.2 435.6 223.0
These are values how fast particular router can process packets in kilopackets per second (kpps) and what is the maximum speed in Megabits
for packets of 1518 bytes in size, 512 bytes or 64 bytes and no bridging involved in packet processing which are processed with fast path option.
