Ethernet Vendor Name in Tools/IP-Scan
Dear guys,
It would be really useful to have the IP SCAN tool have a column “MAC Vendor”, showing the IEEE-registered vendor associated with the MAC address (first three bytes).
You can download the table at:
http://standards.ieee.org/develop/regauth/oui/public.html
and convert it to a more compact code using:
wget “http://standards.ieee.org/develop/regauth/oui/oui.txt
sed -ne ‘s/^([0-9A-F]{6,6})…(base 16)\t\t(.*)$/\1,\2/p’ oui.txt > macvendors.txt
It’s about 400k in size. If that is a problem, it might be added as a optional package?
Thank you!
