Hi All,
I have alredy posted question in RouterOS Community Support [General], but if the issue is related on ospf/mpls this forum shuld be the correct place to post.
I’m trying to setup this scenario:
Cisco Catalyst Switch with ethernet port in trunk wich allow some vlan (vland id are 10, 50, 51 ecc.)
In this port trunk I have connected the ether1 of rb411 of side A
On this rb411 i have defined vlan interface with proper vlan id on the interface ether1
then there is a wireless link setup based on station from side A ed ap bridge in the side B
on the side B I have another rb411 with ether1 connected in another switch port with same trunk configuration.
When I configure in the rb411 ospf routing (necessary to setup mpls in according to reading http://wiki.mikrotik.com/wiki/MPLSVPLS#Prerequisites_for_MPLS) ospf and mpls work fine but from the ethernet level I can’t see (and ping!) ip address assigned to vlan interface (for testing pourpouse I have assigned ip addresses of the correct vlan subnets to all vlan interface) from other pc connected to the same switch (side a) but in a access vlan port.
What is wrong?
I would like to transport vlan’s over mpls network to connect them to specific vpls to obtain:
-one mpls cloud
-vpls1 for wisp services to sell internet connectivity to customer that connect in 5ghz to our ap’s
-vplsA for customer A that need point-multipoint connectivity in MAN (covered by mpls cloud)
-vplsB for customer B…
-vpls mgm for management of all network (including Dude, winbox visibility ecc. ecc.)
Thanks in advance and best regards.
Luciano
