Everquest ports
Hi all,
Has anyone had to deal with opening ports or whitelisting for customers on hotspots running Everquest the game?
They apparently want the below open. I believe the 1024-6000 are primarily “outgoing”
the others are "bi-directional.
Application: EVERQST Port range: 1024 - 6000 Protocol: TCP/UDP
Application: EVERQST1 External port: 7000 Internal port: 7000 Protocol: TCP/UDP
Can someone guide me to direct/open these ports only to a specific user/IP?
You can make NAT rules for that,
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT
However it might be not good way to forward all ports to the specific user.
Perhaps this application could be supported by UPnP?
Thanks,
:bulb: I didn’t think that one through, at all
Problem solved. Simple Nat. And I did narrow down the ports without doing UPnP
