everything+hotspot doesnt work
Hi
Is there a way that I can make things like mark routing or even load balancing with hotspot enabled, because I cant make anything work that involves a hotspot in the setup, it just pops me a error or gives me a issue, I bought a 10port router for a reason, and now I need individual units to make simple things work :frowning:
a router for hotspot, another router for load balancing, and so on
ERROR: Not found
on browser
and that mangle trick: > Hotspot: auth
Does not work!
Can you share your configuration & explain details about problem?
I’ve been told by mikrotik support that multiple gateways on a hotspot can cause issue’s
So I guess it cant be done, so I added a 2nd router for it, against my will!
I don’t have a config for it anymore, but I used route mark and ppc load balancing from wiki with a hotspot enabled, basic basic stuff, that doesn’t work, disable hotspot server, and it works :confused:
I don’t have a config for it anymore, but I used route mark and ppc load balancing from wiki with a hotspot enabled, basic basic stuff, that doesn’t work, disable hotspot server, and it works > :confused:
