So far I have implemented a few things.
DHCP 192.168.0.1/24
Basic Firewall Filters for Client protection.
Basic Firewall Filters for Router protection. Still being discussed a bit.
A working Port forward. Basic principle on how that is done documented.
Graphing - well only a bit. Could do with expansion.
(I will keep typing and posting because it also serves to complement my own documentation)
Next item is static addresses for some equipment, like servers and other tools.
This should probably be done on the Switch, following the principle on implementing things as close to the equipment as possible. I can assign static addresses from the Router DHCP range but they time out. I am also told that I should be prepared to define these static addresses on the devices as well. Trying to read up what it says under IP in the manual, but as far as I can see that topic is not addressed here: https://help.mikrotik.com/docs/display/ROS/IP and I am not getting the logic. Either you have a DHCP range and assign addresses dynamically via that, or… what? I am not really catching the assign fixed IP part. It can’t be enough to just set the IP on the equipment and expecting it to pop up on the Switch or the Router.
Also if I do it on the Switch I am guessing the Router might need some configuration to handle that…?
Anyone has a quick 1-2-3 on how to do this?
Since I know some will ask this is my Router Config. The Switch Config is default. Both running 7.1.1.
# feb/16/2022 09:24:15 by RouterOS 7.1.1
# software id = Y7E5-SEZ7
# model = RB1100x4
# serial number = D8580E4D7A72
add name=bridge1
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.1.0/24
add address-pool=dhcp interface=bridge1 name=dhcp1
/port
set 0 name=serial0
set 1 name=serial1
/queue simple
add comment="trying to keep at least 10MB to all clients at all times" \
limit-at=10M/10M max-limit=100M/100M name=queuebw10 target=192.168.1.0/24
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=ether13
/interface detect-internet
set detect-interface-list=all
add interface=ether1 list=WAN
add list=LAN
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
/ip arp
add address=192.168.1.234 interface=bridge1 mac-address=2C:76:8A:AD:27:86
add address=192.168.1.10 interface=bridge1 mac-address=00:25:90:4B:6B:4B
add address=192.168.1.16 interface=bridge1 mac-address=00:15:5D:01:EA:01
add address=192.168.1.33 interface=bridge1 mac-address=00:15:5D:01:EA:08
add address=192.168.1.35 interface=bridge1 mac-address=00:15:5D:01:EA:09
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.1.5 client-id=1:8:55:31:c1:67:57 mac-address=\
08:55:31:C1:67:57 server=dhcp1
add address=192.168.1.30 mac-address=58:9E:C6:19:81:1D server=dhcp1
add address=192.168.1.100 mac-address=10:BF:48:89:F3:3C server=dhcp1
add address=192.168.1.10 client-id=1:0:25:90:4b:6b:4b mac-address=\
00:25:90:4B:6B:4B server=dhcp1
add address=192.168.1.40 mac-address=18:16:C9:D0:8B:B2 server=dhcp1
add address=0.0.0.0/24 gateway=0.0.0.0 netmask=24
add address=192.168.1.0/24 gateway=192.168.1.1 netmask=24
/ip firewall address-list
add address=192.168.1.2-192.168.1.245 list=allowed_to_router
add action=fasttrack-connection chain=forward comment=\
"fast-track for established,related" connection-state=established,related \
hw-offload=yes log=yes log-prefix="fast-track for established,related"
"accept forward established,related, untracked" connection-state=\
established,related,untracked log=yes
add action=drop chain=forward comment=invalid connection-state=invalid
"drop access to clients behind NAT form WAN" connection-nat-state=!dstnat \
connection-state=new in-interface=ether1 log=yes log-prefix=\
"default configuration, input accept established,related,untracked" \
add action=accept chain=input comment="allowed to router" log=yes \
src-address-list=allowed_to_router
add action=accept chain=input comment="icmp allowed" log=yes protocol=icmp
add action=drop chain=input comment="drop access"
add action=drop chain=input comment="drop invalid" connection-state=invalid \
log=yes
add action=drop chain=input comment="drop all not coming from LAN" \
in-interface-list=!LAN log=yes
add action=accept chain=forward comment="accept in ipsec policy" \
ipsec-policy=in,ipsec
add action=accept chain=forward comment="accept out ipsec policy" \
ipsec-policy=out,ipsec
add action=drop chain=forward comment="drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat in-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=22022 in-interface-list=WAN log=yes \
log-prefix=sftp-inleed protocol=tcp src-address=5.150.195.195 \
to-addresses=192.168.1.22
/ip firewall service-port
set ftp disabled=yes
set irc disabled=yes
/ip service
set telnet disabled=yes
set ssh disabled=yes
/system clock
set time-zone-name=Europe/Stockholm
/system identity
set name=mt-ro-homered
/tool graphing interface
add allow-address=192.168.1.0/24 interface=bridge1
/tool graphing resource
