Evry Day Kernel Failure?
after upgrade from 5.9 to 5.13
RB800 reboot 4-5 times a day
than downgrade to 5.12 but same
Any Help?
Tnx
Hi!
Do you use bridge?
If so activate rstp on each bridge…
RGDS
Hello!
Do you have multi-CPU enabled? if so, try to disable!
I had same problem until i disabled multi-cpu support!
Regards!
what routerboot?
/system routerboard print
Hello!
Sorry, my mistake xD
I didn’t saw that you are using RB800, i had same problem, but on x86 Dual Core system.
Regards!
Yes with multi core PC I was having long time ago kernel problem but I m using RB800 just for p2p Link
no special config just AP bridge<->Station WDS no firewall…
today I upgrade to 5.14 this show up bad-blocks: 0.1% (if this is the case but I m not shure)..
All my x-86 dual-core machines have problem with 5.x. One machine runs fine on 5.12 now, but another machine of same type will not. I put it back to 5.6 and it ran for ten days, then locked up. Had to power it down to fix it. This is very frustrating. I’ve been using Mikrotik since somewhere around 2002 and have been a big supporter, but lately between this and RB450G capacitor problems I am afraid I am going to start losing my customers. I wish they would be more careful with the products/versions they release. Seems like every O/S release fixes something and breaks something else. And now there is talk of V6.x? Crazy!!!
