I need to exclude traffic from a specific public ip from being procesed by fasttrack. The reason is that the site won’t work properly when fasttrack is enable. If somehow I can bypass that connection from fasttrack, I will be able to access the site normally, without having to disable fasstrack.
Thank you Mkx, I’ve already try adding a chain forward accept rule with the src address. The result was that some traffic was captured by the rule, but the site still fails. Any ideas?
try to add another route below but set the said ip address as dst-address and enable connection-state “established, related” too, so traffic back to the originating IP also does not “fall into” fasttracking
