Exclude some side from hotspot limitation
Is it possible to exclude some side from hotspot rate limit?
ex: user A can get 512kbps to access internet and he can get 100Mbps to local web servers.
I am using User Manager to manager user account.
Rgds,
I believe you can 1) manually setup/edit the user in UM or 2) use a different profiles to achieve what you want to do.
can u talk more detail about the option 1 and 2?
Is it possible to do it? Pls help to light up
For option 1) simply log into userman and create the user in the context menus provided - should be straight forward?
  1. Winbox>system>hotspot>user profile>add> now create a template (if you need to change anything from the default)
    Then once you’re happy with the settings in there goto:
    Winbox>system>hotspot>users>add> now create the users within there - the 2nd tab sets the limits. But please make sure you select the hotspot you what that user to be active on.
Remember method 2 will only work if your RB is running both radius and userman on the same system.
