Hi all,
Thanks to forum's advices I now have a working IPsec setup (NordVPN provider) for my CRS309-1G-8S+
Lately, I also configured a site-to-site WG connection between my mikrotik (192.168.30.x network) and a remote fritzbox (192.168.178.x network).
The issue that I have with this setup is that, when IPsec connection is running, I cannot reach the WG subnet (192.168.178.x).
A workaround I found is adding 192.168.178.0/24 subnet to the address-list used by mode-config.
Would you see an easier and cleaner solution to isolate WG from IPsec?
This is my routing table:
[admin@MikroTik] > /ip route print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, s - STATIC, d - DHCP
Columns: DST-ADDRESS, GATEWAY, ROUTING-TABLE, DISTANCE
# DST-ADDRESS GATEWAY ROUTING-TABLE DISTANCE
DAd 0.0.0.0/0 192.168.1.254 main 1
DAc 10.6.0.7/32 sfp-sfpplus2 main 0
DAc 192.168.1.0/24 sfp-sfpplus2 main 0
DAc 192.168.30.0/24 vlan30 main 0
DAc 192.168.88.0/24 bridge main 0
;;; Remote LAN via WG
0 As 192.168.178.0/24 wg1 main 1
My current config is right below.
Thanks to all for your help!
Lorraine
# 2026-01-01 22:20:56 by RouterOS 7.20.6
# model = CRS309-1G-8S+
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge vlan-filtering=yes
/interface wireguard
add listen-port=13231 mtu=1412 name=wg1
/interface vlan
add interface=bridge name=vlan30 vlan-id=30
/interface ethernet switch
set 0 l3-hw-offloading=yes
set 0 l3-hw-offloading=no
set 1 l3-hw-offloading=no
set 3 l3-hw-offloading=no
set 4 l3-hw-offloading=no
set 5 l3-hw-offloading=no
set 6 l3-hw-offloading=no
set 7 l3-hw-offloading=no
add name=WAN
add name=LAN
add name=WAN30
add name=LAN30
/ip hotspot profile
/ip ipsec mode-config
add name=NordVPN_it responder=no src-address-list=nordvpn_it_list
add name=NordVPN_jp responder=no src-address-list=nordvpn_jp_list
/ip ipsec policy group
add name=NordVPN
/ip ipsec profile
add name=NordVPN
/ip ipsec peer
add address=it256.nordvpn.com disabled=yes exchange-mode=ike2 name=NordVPN_it profile=NordVPN
add address=jp674.nordvpn.com exchange-mode=ike2 name=NordVPN_jp profile=NordVPN
/ip ipsec proposal
add name=NordVPN pfs-group=none
add name=pool_vlan30 ranges=192.168.30.10-192.168.30.100
add address-pool=pool_vlan30 interface=vlan30 name=dhcp_vlan30
/port
set 0 name=serial0
/certificate settings
set builtin-trust-anchors=not-trusted
add bridge=bridge comment=defconf interface=ether1 pvid=30
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf disabled=yes interface=sfp-sfpplus2
add bridge=bridge comment=defconf interface=sfp-sfpplus3 pvid=30
add bridge=bridge comment=defconf interface=sfp-sfpplus4
add bridge=bridge comment=defconf interface=sfp-sfpplus5
add bridge=bridge comment=defconf interface=sfp-sfpplus6
add bridge=bridge comment=defconf interface=sfp-sfpplus7 pvid=30
add bridge=bridge comment=defconf interface=sfp-sfpplus8
/interface bridge vlan
add bridge=bridge tagged=bridge,ether1 untagged=sfp-sfpplus3 vlan-ids=30
add interface=sfp-sfpplus1 list=WAN
add interface=sfp-sfpplus4 list=LAN
add interface=sfp-sfpplus5 list=LAN
add interface=sfp-sfpplus6 list=LAN
add interface=sfp-sfpplus7 list=LAN30
add interface=sfp-sfpplus8 list=LAN
add interface=sfp-sfpplus2 list=WAN30
add interface=ether1 list=LAN30
add interface=sfp-sfpplus3 list=LAN30
/interface wireguard peers
add allowed-address=192.168.178.0/24 endpoint-address=<FRITZBOX_ADDRESS> endpoint-port=51730 interface=wg1 name=fritzbox \
persistent-keepalive=25s preshared-key=<PSKEY> public-key=<PBKEY>
add address=192.168.30.1/24 interface=vlan30 network=192.168.30.0
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add address=192.168.30.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=192.168.30.1
/ip firewall address-list
add address=192.168.30.95 list=nordvpn_jp_list
add address=192.168.30.95 list=nordvpn_it_list
add action=fasttrack-connection chain=forward connection-mark=!ipsec connection-state=established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related
add action=accept chain=input comment="Allow Wireguard from WAN" dst-port=13231 in-interface-list=WAN protocol=udp
add action=accept chain=forward comment=Wireguard-to-LAN in-interface=wg1 out-interface=bridge
add action=accept chain=forward comment=LAN-to-Wireguard in-interface=bridge out-interface=wg1
/ip firewall mangle
add action=change-mss chain=forward comment="MSS 1352 for Wireguard" in-interface=wg1 new-mss=1352 protocol=tcp tcp-flags=syn tcp-mss=\
1353-65535
add action=mark-connection chain=forward comment="Mark IPsec out" ipsec-policy=out,ipsec new-connection-mark=ipsec
add action=mark-connection chain=forward comment="Mark IPsec in" ipsec-policy=in,ipsec new-connection-mark=ipsec
add action=masquerade chain=srcnat in-interface=vlan30 out-interface-list=WAN30
/ip ipsec identity
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=NordVPN_it peer=NordVPN_it \
policy-template-group=NordVPN username=
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=NordVPN_jp peer=NordVPN_jp \
/ip ipsec policy
add action=none dst-address=192.168.30.0/24 src-address=0.0.0.0/0
add dst-address=0.0.0.0/0 group=NordVPN proposal=NordVPN src-address=0.0.0.0/0 template=yes
add comment="Remote LAN via WG" disabled=no dst-address=192.168.178.0/24 gateway=wg1 routing-table=main suppress-hw-offload=no
/system clock
set time-zone-name=Europe/Rome
