Excluding dynamic entries from [ find ]
If I want to dump the old firewall rules out before adding a new set I use
remove [ find ]
The trouble is that if there is a fasttrack rule, [ find ] returns the dynamic packet counter entry, and remove fails and the script stops executing the current code block. I’m not sure to specify non-dynamic entries to the find command
My current workaround is like this, but I’d like to know if there’s a way to identify dynamic entries with find as I potentially have this problem in other places as well, such as removing static entries from the routing table
remove [ find action!=passthrough ]
remove [find where !dynamic]
or
remove [find dynamic=no]
Or you can use on-error.
But above solutions are better.
Not sure why you like to remove all firewall rules, can you explain what is the goal with this?
