Execute php code after connecting to the hotspot
Hi all,
I have generated a hotspot and I need to touch up its code to be able to capture the email address of the user who connects. I am using the external portal configuration and I have the following problem, when I connect to the hotspot, valid data and it gives me connection, from that moment I can not make any call to files with extension .php. That is, I can not run from the browser anything of the type www.midominio.com/a.php
shows error 404 not available.
The file exists and if I connect to the url from any port of the router or by wifi but without entering the hotspot it can run without problem.
Could someone help me?
The router is rb2011uias-2hnd with 6.43.11
Thanks in advance
