Exists miniPCI working on ROS at 11Ghz, 18GHz or 28GHz?
It is impossibile?
did you find any?
do u know miniPCI voltages? :smiley:
I m searching for…
3.3V.. why?
This class device usually have indoor unit and outdoor RF unit. I think mPCI power resource is not enough to supply RF outdoor unit.
and do you know uvb voltages? :laughing:
Not, can you help me to understand? :frowning:
ect. 18GHz saf cfip power consumption ~24W and radio radiotion is ~2V.
Sorry, what’s:
“saf cfip power consumption”
and
“radiotion”
these are uvb (11,18,28GHz) devices. SAF Tehnika is Latvian company which developing uvb RF devices, such as Czech Alcoma.
Yes I know SEF and Alcoma… but why not can find miniPCI for this GHz or module that shift a 5 GHz miniPCi to 11 GHz or above?
because miniPCI can’t hold it - simple as that.
But I see some devices that i suspect are Mikrotik based…
Ok, you say that miniPCI can’t hold.. but why? :frowning:
these issues you should ask to manufacturers. :laughing:
are you that say that this is not possible… :frowning:
i think you is looking for the 11Ghz link to provide higher bandwidth.
Is the mikrotik routerboard ready for it?
This is the issue we should think about it.
So you’re saying you don’t understand it well enough to be able to explain it to anyone?
if it was possable to make minipci card with 11,18,28Ghz, i think - it where be already done.
