With hat in hand I am back to the MikroTik knowledge well looking for some insight. How do I create an access VLAN on the router port 3, within the current configuration?
With the help of the community Implementing a VLAN solution - #47 by colporteur I managed to get the above setup working using bridge VLANs.
I wanted to build on the success by expand the configuration, adding a VLAN acces port 3 on the router. My goal was a device would connect to port 3 and receive an IP address from the associated DHCP pool. I am unable to get it working.
I can expand access ports on any of the switches but no success on adding an access port on the router. I’ve tried numerous configurations, to many to list here before seeking help. After countless hours I have run out of attempts.
What changes do I need to make in the router code to configure a VLAN110 as an access port 3?
# 2026-01-07 15:44:29 by RouterOS 7.20.6
# software id = JPC6-9H6F
# model = RB750Gr3
add admin-mac= auto-mac=no comment=defconf name=bridge
/interface vlan
add comment=VLAN interface=ether5 name=vlan110 vlan-id=110
add comment=VLAN interface=ether5 name=vlan120 vlan-id=120
add comment=VLAN interface=ether5 name=vlan130 vlan-id=130
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.87.200-192.168.87.254
add name=dhcp_pool1 ranges=192.168.110.200-192.168.110.254
add name=dhcp_pool2 ranges=192.168.120.200-192.168.120.254
add address-pool=dhcp interface=bridge name=defconf
add address-pool=dhcp_pool1 interface=vlan110 name=dhcp1
add address-pool=dhcp_pool2 interface=vlan120 name=dhcp2
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add address=192.168.87.1/24 comment=defconf interface=bridge network=\
192.168.87.0
add address=192.168.110.1/24 comment=VLAN interface=vlan110 network=\
192.168.110.0
add address=192.168.120.1/24 comment=VLAN interface=vlan120 network=\
192.168.120.0
add address=192.168.130.1/24 comment=VLAN interface=vlan130 network=\
192.168.130.0
/ip dhcp-client
add address=192.168.87.0/24 comment=defconf dns-server=192.168.87.1 gateway=\
192.168.87.1 netmask=24
add address=192.168.110.0/24 gateway=192.168.110.1
add address=192.168.120.0/24 gateway=192.168.120.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.87.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment=VLAN
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment=VLAN src-address=192.168.110.0/24
add action=masquerade chain=srcnat src-address=192.168.120.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set
/system identity
set name=Farmstar
/tool mac-server
/tool mac-server mac-winbox
