I’m considering adding various containers to customer routers that would require additional writes, and would like to expand storage for that purpose… but only internally. Specifically, I don’t want the customer to be able to pull a USB drive off their router.
Which MikroTik options both support containers and have some provision for expanding storage internally?
Same issue as above (ARM 32 bit) but it has a SD Card slot (though SD cards are usually not re-known for their resistance to multiple writes, it depends on what your containers do, if they would be good enough).
First you need to specify what kind of customers and routers you are targeting…
It would be completely different for “home internet users that want a WiFi router at low cost” and “corporate customers who want a high performance branch router”, for example.
I was unclear, but I was intentionally asking in a general way which MikroTik routers have the ability… so I could determine which types of customers could benefit (And so the answers would have value for others). I have a range from residential to various types of businesses.
In general, not many. But maybe that will change when containers become more popular and/or become the new way to extend functionality beyond what MikroTik want to support in RouterOS.
