Quick Question:
what’s the average active users that RB951G-2HnD can handle?
if i have more than 20 users connecting to the AP would it be a good idea if i replace it with RB2011UAS 2HnD IN?
rb 951 ui
rb 951 g
rb 2011(wireless version)
has the same CPU, amount of memory ram, and wireless chipset.
the wireless performance and behavior will be practically the same.
I found that its a very capable wireless accesspoint have seen 40+ users without problem.
Take in count that serving many users need some measures to guarantee a good service on any accesspoint:
do a proper site survey to set the equipment location the more optimal possible and check the coberture area, and proper power level required on the accesspoint.
do a spectral scan to assure no interference affect the channel you use
use traffic control (QoS) to share evenly the bandwidth between the wireless users.
here are a guide to high density implementations
http://www.cisco.com/web/strategy/docs/education/cisco_wlan_design_guide.pdf
