explain in installation
hi every body
can I instal windows on partition and Mikrotik on other at the same hard disk
c:\windows
d:\mikrotik
WHY?
i need it so much
because i used my computer for multi things
nad used this RouterOS for test
well assuming you were able to get both systems to dual boot, you understand that only one OS can run at any given time?
Mikrotik doens’t know anything about your D:\ drive. It’s a different operating system. You can’t install it in a folder. It will erase all your partitions before installing. You should use a Virtual Machine if you want to test it.
Google for software called “virtual box”
or
Microsoft’s Virtual PC. Also free.
Regards
Leon
$25 at a flea market - get some old PC.
