export all data and sitting
hello my dears
plez tell me if u have any way to export all data and sitting in microtik
export on screen:
/export
export to file:
/export file=
thanx
and if i want export only account?
what kind of account are you talking about?
pppoe
/ppp secret export
you can use export command on any submenu to export its configuration
thanks
this is right
but if i wana import this sitting
to second mt system i will find some erour on import oprition
can i find solve to this proplem
You can fix errors by opening exported script in any text editor and correcting the code.
Also errors happen if you want to import setting to non-installed packages. For example, if PPP package is disabled or not installed, you won’ t be able to import any ppp configuration.
