the export of the config on the remote client on my workstation (xp/pro sp2) still crashes the whole client with dr watson, on my notebook same softwareconfig it is no problem…
on the “server” (it is only a w2k pro box) it is no problem also
send us your data directory from dude server you cannot export config from. Email address is support@mikrotik.com
Same problem with rc8.
